hey guys , just wondering if someone either profesional or backyard who rebuild engines , machines them ect would mind me hanging around after hours and on the weekends to try and learn a bit about engine building? really keen to help out and learn about engines ?? if not any ideas who i could aproach?
https://www.sau.com.au/forums/topic/343961-random-engine-building/
i just finished building a 308 for a race car your a week too late ,have another 308 thats almost finished as well for my own race car on the stand but im not in a rush just yet to put the heads on that one .
what side of town ru on ?
cheers dean
I'm the same. I've learnt lots by doing heaps of work myself over the years aswell as lots of reading but really wanna learn how to assemble a 26 from the ground up, not really into paying workshops for something I could spend a few hours learning how to do something that I don't even know if they have done it correctly.
Next year I'm actually planning to buy a tig welder and get practicing at welding. Something im keen to try and learn.
I grew up with family into rallying, drag racing, circuit racing ... all in cars and on bikes. So it was a no brainer that I was going to inherit those genes. Rebuilt my first 2 stroke motor at 14, and was servicing the family cars at 16. My first car was my uncle's TC Cortina street/drag car. Did lackey work in workshops from 16-18 then went on to spray painting. Applied to be a RAAF aircraft technician, but an injury at the time stopped me, so settled for working on cars. Had a real head and heart for it back then ... now I just got the head for it. Got fed up with working on cars for a job, so now I just tinker with cars for a hobby as its more enjoyable.
I've done some stupid projects over the years, including a 13B 1600, supercharged SR20DE in a 200B, CA18DET in a 1600, and many other dumb projects that should never have been built (turboed CBR1000 drag bike being one) :) I do all my own work on my cars and bikes, and have done so for more than 20 years. I've even helped out a few SAU members with their cars and shown them a few things to learn along the way too.
I'm all for people learning to DIY. :(
I have a RB25DET out of a S1 here that we can build :( it has a bit of damage but keen to get it up and running and then possibly look into getting a rolling shell :)
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
