My R33 has been stolen..long story
Im thinking of buying an 04 V350 GT 4dr, as im a married man it meets with the wifes approval....but is it really a Skyline?
I would really like to get an opinion on what MODS are available and any info on the car.
Thanks i look forward to others opinions as im just not 100% yet on buying it.
Cheers
  • Replies 53
Posted Images
They are bloody awesome cars and half the price of competitor cars with the same level of performance/reliability/luxury. Drive one and you will know whether you want one or not.
Every mod you can think of out of the USA and they are CHEAP .... only the postage is a bit exxy, but still works out pretty cheap. Obviously being non-turbo there is a limit to how much power you can draw out of them without going FI, but the power is pretty good standard imho.
not too bad needs matching tint front and rear the door water repel things off
you've had yours on the dyno Andrew surely for shits and giggles
what did it make
lol..yep first thing to go those ugly things on the door frame....i compared the R34 stock..and damm it kicked ass hence why im thinking about it.
She made 148.6rwkw at Extreme Horsepower on a Mainline dyno (so 160rwkw on a DynoDynamics). A stock R34 should make about 130-140rwkw. My stock ADM S15 only made 114rwkw!
a mate of mine from perth put a supercharger kit on his a couple years back, he said it was a monster, from memory it pulled just shy of 300 rwkw and enough tourque to reverse the rotation of the earth
great car, thats what im probably looking at next, either one of this of a stagea. is that the one from sinergy?? id look elsewhere apart from them though
Yepp Sinergy... and your not the first person to mention i should look elsewere.
That does worry me :thumbsup: .
^^ that look elsewhere comment to my knowledge is based purely on price
but you always pay more from a car yard
i know Rocco and the other Dude whos name slips me at the moment will give exceptional service, as i have had work done by them and would return
hmmm.. understandable caryard is out to make a buck.
Nightcrawler has very valid reason for concern.
Due to the fact that Rob + Rocco are a family friends of sorts they were recomended to me, it all looks ok so far.
+ I got a good discount :thumbsup: .
God knows ive had enough car trouble already this year!
Again, i have had the car indepently looked at to cover my behind...but if anyting untowards happens i will be posting straight away.
Cheers
no it's a Infinity not a Skyline. but still a fantastic car for the money, High end Nissan similar to lexus
plus a huge amount of support from USA aftermarket parts
but we still love ya andrew...lol
^^^ lol incorrect Troy - G35s were made in America, but V35 Skylines were made in Japan. Same car but different car if you get what I mean :)
+1 to that....the entire dash is in Japanese :thumbsup: anyone have G35 books i can use to translate?
But then again can anyone read American?
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
