Guys,
I got a prob with install cooling pro intercooler. baught from just jap last week. any body know how to fix the boost controll hose. pls refer the photo attach. thanks for your help
https://www.sau.com.au/forums/topic/344528-r33-coolong-pro-intercooler-install/
when i put my cooler on (wasn't a cooling pro but i had the same issue), i cut the nipple on and welded it to the pipe from the turbo to the cooler. other people have simply bought a screw in nipple and put that into the pipe.
thanks mate
i'm not a big fan of using plenumn vac lines for boost. i know people in the past (and myself) who have had boost spiking issues when using a line hooked to the plenum. that is why i welded mine into the pipe from the turbo to the cooler. before doing it i would occasionally get a spike up to 14psi (boost was set at 11). after moving it i had no spiking issues.
yeah same ^. much steadier feed from there. doesnt fluctuate as wildly in cold/hot weather either.
1+. thats what i thought. anyway i have hook up a niple to the pipin and fix the thing. thanks
everybody :D
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
