would change AFRs aka just dump in more fuel making the car richer.
that's that i would guess for $12.
Exactly. Tricks the car into thinking it's colder, therefore dumping more fuel into the engine. Will it work? Marginally. Is it terrible for your engine? Well...
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5553410
It changes the signal for the coolant temp sensor not the air temp.
But yeah...cant see it doing anything other than washing all the oil off the bores and ass raping your engine with a pineapple attached to a jousting stick.
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5553795
It will modify any standard ECU by telling the ECU that the incoming air in the intake system is cold
description makes it sound like it's for a air intake temp sensor.
you could essentially just unplug your coolant temp sensor though. will have the same effect. the thing is though, on long trips it may really affect fuel economy if the resisitor in the little box (that's all they are) made the ecu think the engine temp was so low that it ignored the o2 sensor and just ran on the cold start enrichment maps.
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5554012
also won't work on rb20 or rb25 powered cars as they don't have an intake air temp sensor.
i'd also like to know how adding in more fuel (which they say happens in the explanation) equals better fuel economy, lol
I knocked my temp sensor off one day to the ECU, car wasn't too happy about it once warmed up.
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5554024
It could and has worked before.. you just gotta know what it actually tries to do so you don't expect too much.
Generally these resistor/chip/box mods will tap into the coolant temp sensor and lower/raise the resistance value fed into the ecu (depending on the type of sensor you have - some go higher when hotter whereas some go lower when hotter), then once the ecu picks up that the car is supposedly running in a cool environment, it will advance the ignition timing to suit equaling more power.
The main thing it depends on is your OEM ecu having ignition timing advance for colder situations - if the ecu has that and you install this crap correctly, then it will work to an extent.. much like driving some bog stock normal car in 10degree night weather vs a hot summer day (taking into account the air is less o2 rich during your testing the device vs driving during a really cold night and also heatsoak).
You can potentially save fuel by having to be on the gas a little less going up hills or maintaining speed etc as your car will have slightly more torque so you do not need to depress the throttle as much as before the 'mod'.
Long as you have basic electronics understanding, how car systems/ecu works etc, you can do this for a couple of bucks (buy a pot to see which resistance value gives best results then buy a simple resistor in that value).
While it may seem like i'm giving this a good rep.. nope not at all (not saying it won't work either because done right it will as long as your ecu has timing advance for colder running situations, a coolant temp sensor and a conservative factory tune). But it's sometimes nice to know the theory behind things.
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5563746
most ecu's add more fuel when cold, as well as possibly adding more timing, so when at full throttle you will use more fuel, and when cruising you may simply use the same amount of fuel. all in all though, you would normally see worse fuel economy with something like this. i've had cars with dodgy thermostats making the car run cooler and fuel economy was better once the thermostat was replaced.
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5563937
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
