I found on my gtr apexi djetro on a low load ping read about 20. I occasionally still get over 100 on crank I presume from starter motor mesh? The base ignition map has a lot of low load advance. After some fiddling now I never get more than 12. Reset max timing to no more than 32 (was 48) and varified number with timing light. Bp98 always used.
I've heard plenty of RB engine's ping at low rpm high load and the knock sensor hasn't reacted, thats tuning with either PFC or factory ECU. I wouldn't recommend tuning based off feedback from the OEM knock sensor, use it only as a guide along with a proper chassis ear and good understanding of what an engine does when it is detonating.
I've heard plenty of RB engine's ping at low rpm high load and the knock sensor hasn't reacted, thats tuning with either PFC or factory Ecu
Rebuilt engines with power FC?
^^ Spot on, definitely the best advice.
  • 11 months later...
The two better tuners locally to me both use 'knock box'.
What hardware are you guys going to? Phormula?
CHeers
Justin
  • 4 months later...
Ive been using this system for awhile now. But havent seen much press on it.
but today i came across this great spiel on it from high performance academy..
  • Like 1
  • 6 months later...
CHeers
Justin
Justin, ive found the knock box to be the most reliable as a full time tuning option as it can be quickly swapped fom engine to engine easily.
The PLEX unit is awesome but is actually painful to use. It takes a long time to set up to get the same accuracy as the knock box, therefore we only use the PLEX system on big budget big HP setups where the customer is happy to pay for the extra time.
  • 7 months later...
I was informed there was a few broken links to the sound files so i have linked them to the reseller of the knock box who has some great examples.
http://theknockbox.com.au/the-knock-box/sound-recordings/
  • Like 1
Those are great samples, thanks Trent. Sounds like very heavy det too, nasty. Would be interesting to hear varying levels of knock starting with very mild.. eg start from knock-free baseline and then adding 2 degrees in timing every 5 seconds and then train yourself to listen for light knocking as well.
  • 2 years later...
On another forum they are saying that if you use ~original at the end of the link then it works again Trent.  I haven't tried it but several have vouched that it works.
But Photobucket will probably end up closing that loophole eventually as well.
On another forum that I frequent, Street Triple, I informed the admin guys of a workaround for the Photobucket ransom demand.
The dodge was to place the string ~original after .jpg in the Photobucket URL.
Using that, they were able to download all the pictures.
They then modified all threads that used Photobucket links to point to the downloaded pictures that were now stored on their server.
The resulting pictures are stored in a gallery, which is now used instead of Photobucket.
Kudos to that site's admin people.
  • 2 months later...
All the embedded photos are with photobucket, due to a recent owner change they have decided to charge for hosting (399 usd a year)
if you use CHROME this work around will allow you to view allthe missing images.
https://chrome.google.com/webstore/detail/photobucket-embed-fix/naolkcpnnlofnnghnmfegnfnflicjjgj?hl=en
https://github.com/kzahel/photobucket-embed-fix
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
