the fuel pressure reg is to the right bolted on the end of the rail. the other two from what i understand, are fuel dampers to help smooth out pressure surging and spikes. nissan fast also lists them as dampers.
see attached,
  • 6 months later...
so what is the stock 'set' reg pressure, I read somewhere that it is 48psi with varying opinions.. So mine should be 48psi + 12psi boost??
Dont allow for boost predsure when checking at idle. When on 12psi it should rise 12 psi.
yesterday i filled up and again it did almost 20L/100kms the second time round, ridiculous economy - I would have expected it to drink less as its running lean in the mid-upper rpm band..
have you checked the fuel pressure? a dead reg can cause that
either the diaphram stops working properly and it affects pressure or they leak into the vac line and flood the motor.
i somehow managed to kill 3 regs in a matter of weeks and all 3 ran rich under vacuum and leaned right out under boost, fuel pressure just remained constant instead of rising and falling with manifold pressure.
so yer, check pressure and check the vac line for any signs of fuel
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
