the fuel pressure reg is to the right bolted on the end of the rail. the other two from what i understand, are fuel dampers to help smooth out pressure surging and spikes. nissan fast also lists them as dampers.
see attached,
  • 6 months later...
so what is the stock 'set' reg pressure, I read somewhere that it is 48psi with varying opinions.. So mine should be 48psi + 12psi boost??
Dont allow for boost predsure when checking at idle. When on 12psi it should rise 12 psi.
yesterday i filled up and again it did almost 20L/100kms the second time round, ridiculous economy - I would have expected it to drink less as its running lean in the mid-upper rpm band..
have you checked the fuel pressure? a dead reg can cause that
either the diaphram stops working properly and it affects pressure or they leak into the vac line and flood the motor.
i somehow managed to kill 3 regs in a matter of weeks and all 3 ran rich under vacuum and leaned right out under boost, fuel pressure just remained constant instead of rising and falling with manifold pressure.
so yer, check pressure and check the vac line for any signs of fuel
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
