Hey all,
I spent a good couple of days last week reading all the threads in the FI section and the general maintenance section to make sure I bought the right spark plugs for my car, and I ended up going with NGK Iridium BKR7EIX which are gapped to 0.8mm from factory; only put them in my car on Friday.
But my car is now with Andrew at Hyperdrive waiting to go on the dyno and he called me up to ask what plugs I have. When I told him, he said they are definitely going to have to come out, the plugs need to be gapped to a maximum of 0.7mm but ideally 0.65mm. So it appears I have wasted a hell of a lot of money as the Iridiums can not be regapped and now Andrew thinks he will needs to waste dyno time seeing if they will misfire, then waste time removing the plugs and replacing them, etc.
But wherever I look on SAU, everyone recommends using 0.8mm gaps for boost over 12psi. I'm not sure what boost he is intending to run, I know the turbo I'm using has a 20psi atmospherical actuator so low boost will probably be around 15-18psi. I had been expecting the car to make between 350-380rwhp on high boost. Are his fears correct and I've made a mistake choosing those plugs, or am I getting in a panic over nothing?
Cheers,
Martin.
https://www.sau.com.au/forums/topic/345346-spark-plugs/
I went to the drags last week and was miss-firing down the strip, that was about 1.3 bar and the plugs are ~7,000kms old. It got worse as the night progressed :blink: Still, I managed at 13.036.
I think next plug change I'll be looking to re-gap below 0.8mm, but I just use copper plugs. Why can't you re-gap iridiums?
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5563856
Yeh and KYP have put all sorts of sensors on the valley cover that need to be unplugged and removed. Took me about 3 hours to do it on Friday, but it was the first time I've done it on a Skyline. Could probs do it quicker next time.
I just got Iridiums because I figured it's better to spend $85 once every 60000kms than however much coppers cost every 5000kms.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564031
i have a brand new set of the copper plugs you need sitting here if you need them asap
gap depends on a few things, mainly boost and condition of your coilpacks. but unless you have some really good coilpacks you'll need a smaller gap than .8 for 15+psi
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564365
When i used splitfire coilpacks i was running .8mm or maybe a bigger gap and no misfires with 18psi.
I always replaced my sparkplugs every 5000kms with copper ones.
If you are running original coilpacks, i would gap a set of copper plugs down to .6mm to stop the misfire problems on high boost.
Otherwise get a set of aftermarket coilpacks and stick to the iridiums since you have trouble taking out the sparkplugs.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564614
Bro, if your actuator has a spring pressure of 20psi you wont be able to run under that boost pressure...
Yeh 20psi atmospherical, so at the manifold will be 15-18psi. What I've been told anyway... My boost gauge reads 16psi with the boost controller switched off, so I guess that's correct.
coppers all the way man, do not bother with iridiums - you should have picked up on that if you did read all the threads :P
change them every 2nd or 3rd oil change :)
I know, everyone vouches for coppers but I went for Iridiums because I didn't want to be changing plugs every 5000kms lol. I will probably go with coppers next time.
Anyway, car doesn't have any issues as far as I know... I have Splitfire coilpacks. It does have a slightly rough idle like it's misfiring at idle but I thought that is more likely from the 650cc injectors not the spark plugs???
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564768
5000kms is far too early for coppers!
ive done 12,000km on mine (bcpr7es), still like new and never mis fired - I run a heat range 7 though as i dont waant any chance of pre-ignition although a 6 would be better for a daily driven car but eh, better safe than sorry
ill change mine at 15,000km even though i know they will go more, just good to keep it routine instead of waiting for a failure
Edited by snozzle
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5564769
Use NGK copper BCPR7ES and gap to .8 and will be sweet
Try for the ones without the R if you can though. From memory, the R is a resistor type or something and has a slightly weaker spark... but it's there to reduce electronic knocking/pulses? I should google it- no wait, you google it for a better answer.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565355
This. Dont know why everyone does it at 5,000km. When I pull them out after 10,000km they still look fine.
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565358
Probably depends on your tune/mods and how you drive as well I guess. You're a pussy driver and have no fast and furious mods, so yours last longer :bunny:
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5565367
I am using irridium plugs and have been for the past year or so. No problem what so ever with them. on low or high boost and they are gapped at 0.8... and I am still using standard coilpacks at the moment as they are still going strong.
I used them for the same reason as Hanaldo... I didnt want to unplug / unscrew everything every 5k or so...
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5566341
The trionic system uses the resistor ® type spark plug to read combustion chamber conditions and "inform" the ECU about boost and ignition advance requirements for the engine in real time and continuously. This is why you must use resistor type plugs
https://www.sau.com.au/forums/topic/345346-spark-plugs/#findComment-5566350
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
