Yea that's right mate! After driver side without holes
sorry dude sold that long ago
non abs bm44 rake master cyl?
car was a series 2 , and BMC is gone
in the next few days ill list what i have left
Im after the LH door
post code is 7054 in Tassie can i please get a couple of pictures of it looking down the line n all ? send them to [email protected] asap *VERY KEEN TOO BUY* :D
Hi, do you have the front inner mud guards? The piece for the inner front and the inner front back?
If you do, I'll pick up the pair for the front. Please PM me if you do.
Cheers.
  • 3 weeks later...
