Ok chuckie you can take it confrontationally.
For the rest of the SAU community I am suggesting that if drive was suddenly engaged on a dyno the consequences to life are very high. No driveshaft = no chance.
There has been an incident on a dyno in Sydney where the operator nearly lost a leg when drive suddenly engaged on an R32 GTR years ago. Whilst this might be unlikely, for the 10 minutes it takes to remove the driveshaft it is worth the time.
Driving on the road is a different matter.
Thank`s Wolverine ,i seen few thing`s happen on Dyno`s & never nice, but it`s save as the System is disabled,the shop that did forum members car is happy with this,so iam not sure why your all bagging us about it :unsure: it`s in workshop manual why the negativity :thanks:
Forget it Charles, the idiots who have it stuck in their mind that it is a bad thing will never be convinced.
For the record, a SOLID 4WD light does NOT mean the system is in AIR BLEED mode, it means that you have started to drive with the bleed wire unplugged.. i.e. IT'S AN ERROR
The workshop manual provides TWO methods of putting the car in 2WD mode, one is drop the front prop shaft, the other is the method I have outlined.
The only way the system can engage 4WD again is if you turn the car off.
If you're that scared, then don't do it. Simple. Just don't come on here and bag people that have PROVEN it works.
I read and re-read what I wrote and I just can't find the bit where I said pulling the plug was wrong or would cause damage to the car.
On the other hand I was really pleased to have the information at hand to be able to stick it in 2WD for road use.
Well if you two want to get our knickers in a knot by reading waaay too far into what I wrote there isn't much I can do about that.
Just for the record, if you are putting a car on a two wheel dyno I would strongly suggest removing the front drive shaft. If there is any electronic glitch while the drive shaft is still connected there could be catastrophic consequences.
What is that then?
Honestly, I'm over helping and providing information to people in this section.
From here on, I shall keep everything I learn to myself.
Edited by bubba
Do you really want an explanation??
1. A car running on a dyno at 120km/h with switch disconnected = no problem
2. A car running on a dyno at 120km/h with driveshaft removed = no problem
Electronic glitch occurs perhaps 1/10,000 - 1/1,000,000?? chance and ATESSA re-engages
Case 1 Drive engages and potentially serious injury to operator and car.
Case 2 Zero risk of drive engaging.
It is probably a very low risk but it only takes 5 mins to disengage and bring the risk to zero.
So if you don't want to contribute any more because I agree with you for 99% of what you have said and disagree with you in one minor way then that is your call.
It's not you Wolverine, it's the majority of people in here who are internet warriors just make things so damn hard I cbf dealing with it anymore.
Tim, you know I love you :)
Edited by bubba
Look up high above the kick panel, probably near/behind the bonnet release cable. It's a green socket, white plug, single wire either side.
lachlanw: air bleed mode is simply unplugging the plug and turning the key to ON. If you forget to replug then start the car, as soon as you start moving it will throw up an error (the solid light).
oh my bad . how do you get it in airbleed mode ?
on a slightly related note i just downlaoded the latest version of blazt software which does hicas doignostic and real time display of angles
lol @ your a shit stirer ways lachlan. / thread. I can remember you posting up extensive info on this topic not long ago, i shall search. Havent seen you in here in ages. go back to the wasteland and play with your troll tard buddies. :thumbsup: You usually have some good info to contribute. Blatz software is interesting though.
Edited by dirtyRS4
Thanks for that. I found it. It was wrapped up to one of the wiring harnesses with tape.
I was surprised at how much grip I still had until I really started hooning it. Much opposite lock twirling. Reminded me of a couple of my old skylines n gave me a little smile.
Think I'm gonna fit a switch to it, for occasional sideways fun.
On another slightly different note. Is it worth running it in 2wd mode on my 60 mile run to n from work? Doubtful, but maybe save a little fuel ?
Well Try it & see what you get ,:thumbsup:
agreed, post up the results.
IMO: i think it may be less economic by trying to give you the same power(or more as some said) by putting it all to two wheels.
Just a question; With the gear box being designed for a Manual and not the RWD, would this create any extra clutch wear or gear damage? I know its bad to red line in first in a 4wd, so does this get eliminated by 'f**king off the wire'?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
