Take a look at your own passes of late for example. You have done about 5+ 13.4-13.5's and then a 13.0 and a 13.1
If consistency is the issue, I would challenge you to look at the two times alone that were run AFTER the nitrous/over-rich condition was fixed.
13.0 @ 115.15mph
13.1 @ 115.56mph
Within a tenth of each other and also within half of one mph.
The 3 runs before that were revving only to 6krpm as the car was over-fuelling and turning into a slug (as evidenced by the massive black smoke plumes the car expelled just before every gear change.)
The car felt GREAT on the last two passes of the day....A different car that freely revved to a peak of 7298 rpm with gear changes coming within 100 rpm of this each time. Boost was stable and even for the majority of the run and the car suffered none of it's previous bogging up top as the fuel prob was fixed with correct jetting.
Ther point is this. Every time I run the car, I am aiming to get the absolute most out of it for that run. I don't care if i have a bad launch cos something about the WHOLE run could tell me something I didnt know before. I'm gonna come out and say it that I beleive a low 12 is possible in my car with Radial tyres - RIGHT NOW. Tell me why I should aim for 12.7 when 100 years of drag racing maths and some common sense tells me otherwise?!?!? Tell me why I should be dissapointed with running 14.0 in a stuffed-up run on the way to getting there?!?!?!
As a point of interest, after 4 meets and about 15-20 different runs, I am YET to have a day or night at the track where the car runs more than 0.5sec +/- different for the session.
I'm sorry mate but it just doesn't make sense to me to aim for the mud when there's so much better there waiting.
Adrian
  • Replies 59
I would really like conformation on this.
What is the quickest ET / MPH that an R32/R33/R34 GTS-T/GTT has run with the std turbo intact and untouched?
Will also start a new post in General Auto asking the same question.
Adrian
I just wouldn't be going to the track aiming to knock 0.5->0.9sec off "just like that" because the mph says its possible.
Why? The whole idea about going to the track is to see how fast you can get the car moving. If its capable, try different techniques until you get there.
If it was that easy many more people would be doing it.
Think about it... you have 12-14sec to do what u gotta do. A minor 0.1-0.3sec stuff up anywhere along that 400m is gonna ruin a good time.
I just think consistency is the key to a 'quicker' time. With a 115mph TS a 12.1 flat would not be out of the question thats a whole 0.9sec faster than what has currently been done
I think this consistency thing you're on about refers to driver ability (ie practice makes perfect). The reason why most people run a super time around slightly slower times is for that 1 super run they got everything right. What they need to do is try and mimic these actions again and again until consistency is achieved. Achieving consistency for a slower time may provide good training for a faster pass but its really selling the car and yourself short.
Hope that makes sense...
13.0 @ 115.15mph
13.1 @ 115.56mph
Adrian
i totally agree there is shit tins left in it going by the mph.
what are your 60ft times outta interest?
Both of those runs were with high 2.2's.
Have gone 2.0 on more than a couple of occassions when the tyres didnt suck.
Hoping for the same mph on 2.0's then 1.8 on some Drag Radials.
Adrian
note... slicks :D
Fair enough i aint got a stock turb, but i ran 12.9 @ 109mph... with 2.1 60ft.
On your average 225 street tyre. And my car weights in the same as yours, and you have a decent advantage with your IRS setup
You need rubber mr 2rismo i think!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
