bought Phillip island track last night and the VW tdi for some FWD love :P felt right at home. flat shift sequential is pretty cool too. just a shame diesel means the gear ratios and revs are all over the place.
I can't see Bathurst on the track list, is it released?
It might be under Mount Panorama, but yes, it is released. Been out for a while now. So much fun!
I'm racing a Tuesday night v8 supercars development league. Fixed setup, great for a level playing field. It follows the fincar series and is run by the same guys. Gets a great turnout of 50+, and good close racing
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7295492
  • 5 weeks later...
Any chance to spectate? Twitch or something?
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7321593
I'm assuming Twitch is some online broadcasting service..? I've never used it before. Would have to test it out beforehand I suppose.
Anything which is too cpu intensive has a good chance of making sim racing utter hell haha.
I'll have a look at it though and get back to you :)
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7321624
  • 1 month later...
  • 6 months later...
Thread bump.
The V8 supercars have had an update ford and holden COTF are out :)
Also starting in the next few weeks a huge V8 premier series. Fully broadcast via V8sonline. You have 3 days of pre qualifying and only the top 80 drivers are accepted and split into a support and main race (both broadcast). Then you have official qualifying and sometimes they do a top 10 shootout. Its no reset buttons and realistic live marshals. So you wreck your car in qually if it doesnt drive back to pits you are out. Its really fun and being hosted does not effect irating or safety.
Link for extra info http://members.iracing.com/jforum/posts/list/3297737.page
Also a few paint jobs i did when I was quiet at home. I now run in a team called Multi 21. Enjoy pics :P Hope to see you out on track.
10313732_10154881672030521_6418043923152
  • Like 1
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7478746
I'm looking forward to doing some enduros with driver swaps, So i'll renew tonight I think
Did the Daytona 24hr with a few mates a couple of weeks back. Pretty hectic. There is a Bathurst 12hr this Sunday.
The driver swap feature is pretty sweet, especially for the Bathurst 1000 haha
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7478938
  • 3 weeks later...
i bought bathurst and the lotus 75 the other day. mt panorama is great! especially in the lotus. the ford v8 supercar (not the updated one) on the other hand... having problems with basic tasks like a) braking in a straight line. b) getting back onto the course when on the grass.
IRL, a car does not rotate 180 on the grass at 15km/h. especially not a v8 supercar
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7491424
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
