i bought a new set of splitfires today for my c34 stagea, but i ran into a heap of problems, i blew out my first set of brand spanking new pulse stars. so i swapped them for the regular platinum NGK's i had left over, and guess what, after 30 mins of driving, missfiring and bam 4 of my 6 NGK's ceramics cracked open.......... now i have no plugs left over.
they just keep cracking them open like eggs, anyone have any idea?????
is there proper spark plugs with the right heat setting or cooled head for coil pack cars???
i know bosh has a range of heat set plugs, but does NGK???
i just wasted 200 bucks on plugs today..... its not fun :D
https://www.sau.com.au/forums/topic/346070-anyone-have-trouble-with-splitfires/
i haven't had any issues with splitfire coilpacks and i've run them in 2 of my cars including a set in my stagea at the moment. i know of someone getting a couple of dud coilpacks in a set but they just wouldn't fire.
it may help if you post up the Splitfire part number for the coils (eg. DIS-008, DIS-005), the plug part number, is your car a Series 1 or 2.
Edited by QWK32
possibly a manufacturing fault of the coils, can your send the coils back and get a replacement? are your originals any good, can you put them back in? there's nothing you can really stuff up installing coils, they just bolt and plug in. i wouldn't waste anymore sparkplugs on them.
Edited by QWK32
such a killer, paid 600 for them!!! now gotta go back and get em exchanged. urgh, so what do i do with the plugs????
yeah i know, splitfires are fairly pricey, i just shelled out for a set myself chasing a missfire issue. well it is just a suggestion that the coils are faulty, if your confident you installed them correctly its the only thing that makes sense to me.
if you put the original ones in, provided they are still in a running condition, with a new set of plugs and it runs fine then you've pretty much proved the new coils are faulty. get a set of NGK BCPR6ES they are about $3-$4 a plug. heat range of 6 is good for a mild modded setup.
Wow cracking plugs... this I have never heard of. All that I thought of was are/were they gapped too low??? I'm running 6 series NGK's (BCPR6E) in my series 2 gapped at 0.8mm (were missing at ~5,500rpm @ 18psi w/1mm gap... wtf) and no issues. Sounds like you've got the super-powerful version splitfires?
ive seen plugs crack before under too much heat, pretty crazy if they crack very bad, all you see is sparks flying out the sides.
i think the splitfires i have are the 2nd or 3rd most powerful ones, i think that DIS-010 are the most powerful ones. (from what ive read)
the splits are genuine, bought them from just jap, doubt they would risk selling fakes.
i will go back today, and see what they say. ill aslo buy the set of cheap plugs for the time being, where is best place for them?? just jup had them for 30 bucks but sold out, repco and supercheap??
thanks for all the feedback
Dude...try go to supercheep...and get the next heat rating cooler ei. 8's just get a cheep set. could just be a matter that u need to drop the temp range cause u havesuch a good spark now :P
EDIT: 8 may be a bit too cold....Maybe 7's. Though saying that...the worst that could happen with the 8's is you foul the plugs (If they don't crack at least you know what the prob is and can then try 7's)
Edited by mattye
i was using heat range 7 ngk and also rang 7 pulstars.
both cracked, i havent modified my turbo or anything, just did the boost switch instead of running low to high boost, its constantly running high boost. *bridged the vaccum hoses*.
since im running the cracked plugs till i get a chance to get a new set, they missfire a heap during high boost and if im doing about 2/5th throttle. once i go to half throttle they are fine, but if i go above half throttle till boost kicks in, i get missfiring again.
plus im gettin a heap of backfiring too. alot of popping, hope i wont have to replace my catalytic.
here are some pictures from the sparkies i blew through,
there are pulstars.
I also found out that one was not ngk, (took ngk out and replaced them)
they were autolite double platinum. (there is my reason for them blowing up)
but still wondering about the pulstar plugs, they had a heat range of 7, so should have been fine.
while the autolite had heat range of 6.
here are the pics:
i was using pulstar be1i and autorlite app3923 double platinum plugs, one really really good, and one really shit n cheap
ran autolites at 1.1mm and no luck at all, set to 0.8 and mostly worked, so i got to .6mm and they worked, the pulstar plugs have to be set to 0.6mm or 0.0025"
which worked wonders! untill one cracked.
Edited by Bronx
If brand new Splitfires won't jump the factory 1.1mm gap then there is something wrong with them or the installation. Not familiar with the other plugs you mention - most RBs would be running NGK.
yeah, that chart helps a bit, but even with ngk's ive had problems with 1.1mm gaps. i always run .8mm gaps or .6mm gaps where its specified, always worked great, hard to install anything wrong on any of the products i think :(
its pretty simple, screw out, screw in put pack on, screw pack on and final step, plug it in hehe.
but like said, i highly doubt its the coils in any way, i just think the sparks werent the right heat setting to begin with. both worked perfectly at first, but after a while of running really hot they would missfire.
bought some basic NGK's now, 5 bucks a pop, and they seem to do the job. 0.8mm gapped too. but a decent power loss i must say.
Power loss? compared to what? Try gapping them at the factory 1.1mm
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
