I am planning a trip and looking at fuel stops but have come accross a small problem. For 1 fill up, there isn't a servo that has V-Power or BP Ultimate, only Unleaded 95. I don't want to fill up with just 95 as the octane level is too low. Are there anyways around this or anyways to increase the octane level, without doing any engine damage??
Cheers,
Dan.
https://www.sau.com.au/forums/topic/346451-fuel-adivice-octane/
you could run it on 91 if you want, you just got to run it off boost and with low throttle %'s and you won't be near the knock threshold.
If your worried just put some octane booster in 95 octane and you'll be laughing.
Edited by D_Stirls
  • Like 1
Take a can of Toluene with you ad that to your 91 or 95 should bring you back up to a higher rating. Much better octane booster than mos of the commercial ones on the market
Or just knock a couple of degrees ignition timing out of it
where is your trip most of my trips to Canberra Sydney have BP all the way over pretty sure they all have ultimate
Coming from Taree back home near Adelaide, via Dubbo, West Wyalong, Hay, Mildura then Renmark etc... It's the stretch between Wyalong and Mildura where there is no V-Power or Ultimate. Might not matter, as the roads might be cut off because of the flooding.
NULON octane booster take it up 8 points from memory so it will make 91 into 99. I think it's $25-$29 per bottle that will treat a full tank of fuel. If you only want to take 95 up to 98 you could spread the one bottle over 2 tanks of fuel.
    • 12+ months passed so they have no obligation to do a warranty claim. It leaked from the rear circuit. Front circuit was fine, but I tried many times to bench-bleed and in-car bleed (wasted 1L of Penrite racing brake fluid) to no avail. Threw my old BM50 or whatever the standard R32 GT-R BMC is, brakes went back to normal. So from my very limited anecdotal experience, I cannot recommend HFM, even though a lot of their products looks good. Just my experience (I have a genuine Nissan BM57 in a box waiting to be installed now).
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
