I am planning a trip and looking at fuel stops but have come accross a small problem. For 1 fill up, there isn't a servo that has V-Power or BP Ultimate, only Unleaded 95. I don't want to fill up with just 95 as the octane level is too low. Are there anyways around this or anyways to increase the octane level, without doing any engine damage??
Cheers,
Dan.
https://www.sau.com.au/forums/topic/346451-fuel-adivice-octane/
you could run it on 91 if you want, you just got to run it off boost and with low throttle %'s and you won't be near the knock threshold.
If your worried just put some octane booster in 95 octane and you'll be laughing.
Edited by D_Stirls
  • Like 1
Take a can of Toluene with you ad that to your 91 or 95 should bring you back up to a higher rating. Much better octane booster than mos of the commercial ones on the market
Or just knock a couple of degrees ignition timing out of it
where is your trip most of my trips to Canberra Sydney have BP all the way over pretty sure they all have ultimate
Coming from Taree back home near Adelaide, via Dubbo, West Wyalong, Hay, Mildura then Renmark etc... It's the stretch between Wyalong and Mildura where there is no V-Power or Ultimate. Might not matter, as the roads might be cut off because of the flooding.
NULON octane booster take it up 8 points from memory so it will make 91 into 99. I think it's $25-$29 per bottle that will treat a full tank of fuel. If you only want to take 95 up to 98 you could spread the one bottle over 2 tanks of fuel.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
