I know of an r31 in japan that can cut an 11
and yes 12's are very doable in an r32 rb 20.
ben gtr came pretty close with his gts4.
there is an r32 gtst with an rb26 i qld that runs a low 11's
the bigest thing holding people with rb/20's back is you need to take the big step to run 12's injecotrs big turbo and metal head gasket. the are some strong rb20's around jsut because you dont hear of them doesn't mean they dont exist.
btw there was another from pet in melb that ran a 12.9 or so with a top speed of 120 or so
I expect dr drift here to come close to a 12 if he continues his development program on his car.
meggala
as for me I'm happy with a mid 13 unless someone wants to pay me to run faster
https://www.sau.com.au/forums/topic/3465-fast-rb20s/#findComment-58206
the JMS onveia rb20 powered silvia ran a 12.2 i think, it was running a std motor with big turbo etc, the silvia would weigh about 100kg less as it was stripped out.
Their cerifio rand a 12.9 i think and that has just got a hks 2530 turbo.
The rb20 just needs a good turbo with some good tuning.
https://www.sau.com.au/forums/topic/3465-fast-rb20s/#findComment-58209
boostmeister would be the person you should consult with.. I can see you want to build a daily drivable thats capable of 12s on track..
You might want to visit:
http://www.amkread.co.jp/
and check out some of the records... there should be a HNR32 (GTS4) with RB20DET 2.4litre T88 that ran 9.8s... You won't see any RB20DET 2.0litre cars break into low 11s or 10s as in Japan they don't use full slick tyres.
https://www.sau.com.au/forums/topic/3465-fast-rb20s/#findComment-58297
Mine should be able to (with some traction). Best so far is high 13's (bear with me here, i'm not kidding, it should do 12's). This was on standard, near bald crappy tyres. I also missed the change to second on this run.
I was going past the 1/8th mile mark with the wheels still spinning in third gear. Got traction in 4th. I did have the highest mph for the Street class. My mph was a consistent 110mph.
I think with some traction, should do a high 12.
I got Trust TD06-20G turbo, Trust intercooler, Trust tuned length exhaust manifold. Trust external wastegate. Extra injector. Upgraded fuel pump. Running up to 1.5 bar boost.
:burnout:
https://www.sau.com.au/forums/topic/3465-fast-rb20s/#findComment-59280
perhaps learning to drag race will help your time?
Foot to fhe floor is not the best way to get best times?
You dont see top fuel drivers spinning their wheels through gears and they get pretty good times.
Try applying power gradually
Saying that "Yer she was spinning into 4th" may sound like your car is uber powerful etc... but it doesnt help your et's.
https://www.sau.com.au/forums/topic/3465-fast-rb20s/#findComment-59439
Originally posted by JiMiH
I originally meant in street trim, without slicks
slicks = cheating :rolleyes:
set of bfg drag radial TA's are DOT and therefore not cheating, Niz30 with his mph has a low 11 potential with these sort of tyres and a Whiteline KCA349 diff kit (only $104).
https://www.sau.com.au/forums/topic/3465-fast-rb20s/#findComment-59716
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
