ok i am just geting to the end of my rb30/26 head build and will be pushing some decent numbers, and have been looking at the OS giken 88 but is worht the money? will i kill it?
i wanted it as its a Sequential 6 speed dog box and rated to some pretty good power , has any one used one? killed one? any info really
hollinger was another option but their 22k+ the extra crap and i not sure thier any better the os giken?
any other options on what people are ruining and what other drive line should i be beefing up?
thanks heaps
https://www.sau.com.au/forums/topic/346517-gear-boxs/
yep still H pattern, same as normal except for a longer 1st gear, which combined with a triple plate solid centre clutch can be a bitch on hill starts and in traffic >_<
another I know with similar figures uses a ppg dogbox but doesn't seem to last long between rebuilds and obviously not ideal for the street..
decisions decisions ?? if you can afford it get the hollinger sequential :worship:.
https://www.sau.com.au/forums/topic/346517-gear-boxs/#findComment-5580410
I have gone through 12 std gearboxes. I now use with Redline gear oil. Haven't broken a box since....
holy shit 12ohmy.gif , if you are running the power in your sig. with antilag, I can't see how oil is saving the box, but I know guys with around 600rwhp and standard boxes, they have broken them too but cheap to get a second hand one compared to OS etc, they do change a bit softer now ..
the OP is looking at 800hp I don't think a standard box with Redline oil is the answer.
https://www.sau.com.au/forums/topic/346517-gear-boxs/#findComment-5582408
nah I'm sure any sequential would be awesome, lightning fast changes , are they all dog engagement? could be quite a bit of up keep-maintenance, on the down side...
i believe they are all dog style gears, just wondering what would rebuilds be worth? and how often will they have to be done?
i really want sequential and i would rather buy one box once and not be breaking boxs.
i do not see red line holding a box together at all.
seems hardly any one is using the os giken 88 box :(
any more info peoples thanks heaps
https://www.sau.com.au/forums/topic/346517-gear-boxs/#findComment-5584171
well.....according to the internet (which is never wrong), the os sequential box is actually a rebagded hollinger one. so you are just paying japan premium and getting less service/ support than buying the local one. hollingers come up on here already in skyline bellhousings fairly regularly
you should expect to perform regular maintenance on any high end gearbox - once a season at a minimum.
https://www.sau.com.au/forums/topic/346517-gear-boxs/#findComment-5584214
lol season? this part street car witch will see some circuit and drag work. what sorta km you rekon you would see out of a box before it needs a rebuild? and when you say rebuild its just bearings isnt it?
one thing that leads me to belive you are right about the rebadgeing thing is they use hollinger output shaft , But one thing that is wrong is about the price.
i can get a os giken 88 6 speed in Australia for 15.5k or a hollinger for 22k + the extras you need and the OS comes with every from shift lights to the control box.
https://www.sau.com.au/forums/topic/346517-gear-boxs/#findComment-5584701
os 88 and os88v2 is a complete os giken design. nothing to do with hollinger.
pros.. bigger than a hollinger. apparently shifts well.
cons. 1 piece lay shaft. ie. cant mix and match ratios, and over seas so parts are abit harder to get. also intergral bellhousing not seperate.
both use the chev 26 spline input shaft. ie os r3c etc clutch or custom setup. both come with a digital display for gear selected.
the os is fairly new on the block so not as well used as hollinger.
https://www.sau.com.au/forums/topic/346517-gear-boxs/#findComment-5594160
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
