  • Replies 102
Vladivostok? I guess that's not exactly a small town!
Hmm interesting fact lifted from wiki:
A very important employer and a major source of revenue for the city's inhabitants is the import of Japanese cars.[3] Besides salesmen, the industry employs repairmen, fitters, import clerks as well as shipping and railway companies.[16] The Vladivostok dealers sell 250,000 cars a year, with 200,000 going to other parts of Russia.[16] Every third worker in the Primorsky Krai  has some relation to the automobile import business. In recent years,  the Russian government has made attempts to improve the country's own  car industry. This has included raising tariffs for imported cars, which  has put the car import business in Vladivostok in difficulties. To  compensate, Prime Minister Vladimir Putin ordered the car manufacturing  company Sollers  to move one of its factories from Moscow to Vladivostok. The move was  completed in 2009, and the factory now employs about 700 locals. It is  planned to produce 13,200 cars in Vladivostok in 2010.[3]
Bet you guys get stuff from Japan much cheaper then us! its like a stone's throw to Japan from where you are!
No, NAKHODKA -----> Click
  • 1 year later...
  • 1 month later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
