In my humble opinion if you tune your 3lt to make peak torque across the entire rpm range it will be a much more difficult car to drive, the sheer amount of torque that the three litre can develop at 3000/4800 rpm in an area where the boost is rapidly rising to target wastegate pressure will break the tyre contact patch, assuming your car is not FBW throttle then timing and boost are the only means of controling the power in the mid range. To tune to peak torque above this area and maintain peak torque for as long as possible is the key to tunning any engine.
Look to making modifications to the rear geometry as even the 33 has way to much anti squat in the rear to work with radial r tyre, which will make putting any more than 380rwkw to the ground through a radial challenging.
In my 32 it is a faster car with 490rwk even at a tight circuit like baskerville, as long as the power is controllable and follows throttle request (well as well as you could expect a turbo car to). There are large gains to be had in FBW throttle mapping getting rid of all waste throttle, ie only requesting 40% of plate opening if peak torque can be generated at this opening as this means a pedal reduction of 2% yeilds a reduction of horse power, increasing actual fly opening as rpm increases allways only requesting the min value to net max engine power at given rpm. Gear dependant boost pressure will also help and the holinger and quieff boxes have a voltage output making setting this function up very straight foward. cheers brad
hollinger, + setting up the fly by wire throttle + ECU to run it etc
true you wont do what youve stated above for 30k if your buying new parts and paying someone to do any part oif it , tunning, install etc. What else other than a quaffe/holinger can you poke 420rwkwrwk through without it turning inside out in a race car if the car setup to put it to the ground.
Jerico 4 or 5 speed road race box? Im surprised no one really runs these in Aus. I got rough figures of about $6500 for a 4 speed and ~$8000 for a 5 speed for an 800hp capable box when I looked into it. Edit: With a bellhousing. Oh, and the shifter mechanism will probably necessitate some cutting.
Edited by irokin
A mate has a 5 speed jerico in an FG XR8 that he uses for weekend warrior duties.
The initial cost of the transmission was okay, the bellhousing, clutch, flywheel, thrust bearing, tailshaft, selector and startermotor was the cost killer.
The total conversion set him back more than what an older H6S would have, now planning to remove it and I've ordered a brand new RD6 for him.
The jeri was good to use but the cost of maintaining it has proven to be expensive when it requires parts, so the hollinger is a better option.
For sprints, where you are only allowed to pass on the straight, punch out of the corners is particularly important, you need to get past that slowbie you have been following ASAP and corner exit acceleration will do that for you. With my gearbox and diff an effective rev range of from 4000 to 7000 is required so it has to be well on boost and making good power at 4000 but not run out of puff past say 6000.
So it's not how much power is needed, it's what setup will give me a suitable and highest power spread possible. Makes the car nice to drive too which helps lap times as well.
Would a cheaper alternative be 4d boost mapping with TPS vs boost and a Speed vs Boost map?
Edited by Super_Dude
would be one way of doing it for sure, means running ignition cut for traction control though which is pretty hard on the engine if its on a percentage of cut for the majority of the lap. would be difficult to map due to constantly changing grip levels, maybe you could swing a 9 position trim of a gain compensation to vary it like we do to ulter the target slip percentage and rate in which throttle is slammed shut on slip break out.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
