Looking at a second hand r34 gtr that had a Fuel air controller installed and I was wondering if they are a bad thing for engine life. I would think that most GTR's would have had some mods done to them so was just wondering if I should expect some extra engine wear because of it, and what things I might need to have checked etc. Thanks if anyone has any advice.
By air/fuel controller are you referring to piggybacks? (Apexi SAFC is an example). As for engine life? If they are poorly configured/tuned then yes.. standalone ECU is always the best option, but not the cheapest.
Yes I think so, but I only had a picture to go pre compliance and its since been removed before it was available for inspection. I could only go on what the salesman told me. I will attach a picture if anyone could confirm that it is an air/fuel controller.
that looks like a HKS EVC, which is a boost controller
i dont think HKS make piggyback AFC's that look like the EVC model
Yep just googled HKS EVC and its a splitting image for the HKS EVC 4 boost controller, I guess the salesman would prefer I didn't know that. Jeez its hard to find an honest used car salesman. No wonder he said it won't be going back on after compliance work seeing how much it is worth. Thanks for spotting that paul
technically speaking a car can't be complianced with aftermarket mods (has to be returned to stock), and any aftermarket parts aren't allowed to be reinstalled after the compliance. don't think they are allowed to even sell them (although a lot do). i could be wrong though.
  • Like 1
Yes that makes sense, don't know why he lied about it being something else though.
Fairly new to all of this so I guess I should ask is there anything I need to make sure of when they took it out, something capped off, modified ecu, missing sensors or something like that or is it a fairly straight foward thing to install and then remove.
EDIT: I found a diagram showing how its all connected and it looks like the only area I need to worry about is the wastegate. Seems that the HKS EVC is one of the better ones so I am hoping that the engine won't have suffered too much from the overboosting.Thanks everyone for your help as its going to be a steep learning curve for me.
Edited by thatlbeme
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
