if you do a run with the exhaust dropped and you make more power then you will know the restriction is there... it's a quick and easy way to diagnose a common problem
i'm guessing your cat is collapsed and hindering flow.
you have the parts to make the power you want, just need to get them sorted
if money is really burning a hole in your pocket, go the plazmaman plenum as the stock ones that have been canverted to front facing can lean out no 6. it's not definate, and there are definately 2 schools of thought on the matter that have been hotly debated over the years, but the fact remains that in some instances it has happened, and on that basis i would not run a cut'n'shut plenum on my RB. having said that i do run one on my 4age but that's a 180 deg change, not 90 :)
dont bother with e85 just yet, get the car sorted @ ~340rwkw on pulp and then when you want e85 it'll be a quick and cheap retune... although for this you WILL need much bigger injetors.... think 1000cc
Something is choking it really bad!
Is there a rag in the cooler pipes, blocked/collapsed cat/muffler?
the 426hp run is a lot better.
What do Mercury say about it?
When it was making 426 hp , the car had a couple of illegal mods on it . Like screamer pipe , Atmosphere Bov & Ram pod wasn't boxed in. I got all these mods fixed & made legal . Would this effect performance at all ? Mercury did have a little problem re tuning the car , but nothing which was major & they didn't mentioned anything to me. The only real main problem was the Ecu had to be sent back to Microtech to be cleared , cause the previous tuner put a password on it & we couldn't get it off them. So when it got cleared , they had to start a new tune from scratch . Other then that , all went apparently well & i was really happy with there work on the car. When driving the car home didn't feel any worse , then before i gave it to them , but still really haven't had the chance to really open her up ! They said final results were around the 280 - 290 rwkw.
The only problems with taking the exhaust off & seeing if it runs better , is i live 2 hours south of where Mercury are situated. There is no good local tuners where i live , which are worth taking the car to. So would have to make a 2 hour trip back north to do that ! When i had the car on the hoist the other day did notice the cat & muffler were a bit worst for wear , a bit of scrapings & light dins . The cat especially , also hope there is no rags in the cooler piping , cause they did do a bit of pipe work from the bottom of the turbo which go's to the FMIC. What would u suggest i do about this problem i have ? Take it to a local mechanic for a quick look or exhaust place .
Sounds like you live in ballina or something. Don't worry about the workshop just ask if you can have a couple of runs at the local dyno with the exhaust dropped and see if it makes a difference.
Yeah live at Lismore , do u know this area up this way ? Yeah could try a local dyno around here, i know there is one in Lismore & Ballina . So would just take the exhaust off where the cat bolts upto , then put it on the dyno for a run ?
I lived in tweed heads for 12 years lol. Just unbolt the exhaust at the front pipe (so the cat is unbolted too) and give it a run. Won't hurt anything and will give an indication if what is going on
Thanks for the help , i'll see if i can fit it in before X mas. If not will have to be in the New year . Skyline is only a weekender , so only take it out when i feel the urge to :laugh: Hopefully this will shed a little more light on the situation !
Edited by Tweaky
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
