For sale is my much beloved drift car:
Nissan Skyline, R33 Series II, 1996
Interior still A1 seats all good no interior been stripped,
Front bar not on photos but will go in sale
Ok lots and lots of mods forgive me if i forget some below"
-Aftermarfket forward facing plenum custom
-Z32 Air flow meter
-HKS gate with screamer
-Slotted front roters with new rear bendix brakes
-Flared and rolled rear guards
-Big FMIC custom stainless piping
-HKS coil overs
-3" exhaust system
- Access tuned Apexi power FC with hand controller
- Momo aftermarket racing wheel
-Apexi power intake air pod
-Cusco and HKS sway bars front and rear
-Aftermarket oil catch can
-Built RB25 motor done hardly any k's
-Bosch 040 fuel pump
-Greddy dual stage boost controller
-HKS turbo timer and secondary boost guage
-Garrett aftermarket huge will update type later
-HKS bov
-Bayside clue with fibre glass kit
-Heavy duty clutch
- New 25 Gearbox
-660 Nismo injectors and fuel rail
Contact me on 0431-388-718 or pm me
Car is in Adelaide can be sent to all states
Edited by sus34
https://www.sau.com.au/forums/topic/347606-r33-series-ii-drift-car-fs/
mate does it need much to get rwc? Does it have a locked/welded diff that made it defected or something else?
No welded diff mate, car had rego up till febuary. It's only been tracked twice. Which state are you I'n..?
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
