Thanks for the pic. Well certainly near the same amount of adjustment left on yours as i have. The springs in my actuators must just be weak. Will look at replacing them, although i may look into shortening the arms for a little more adjustment.
  • Replies 43
Posted Images
Justin's suggestion is good. Wire them shut and see if they build boost properly. If they do then yeah the actuators are the problem.
CRD found a bunch of crap in my intercooler when they installed my turbos..... WhereTF did that come from??!!
Well update time... STILL no good!
I have installed brand new 1 bar actuators and i am still having the same problem. Really thought it was solved as the actuator arms i pulled off the turbos were much much easier to pull on than the new ones.
In 4th at ~4k it will only make 0.6 - 0.7 bar... if i rev it more it continues to rise very slowly before i back off.
So...
- I have disconnected the actuator lines and had a run = exactly the same. So it is certainly NOT the ebc.
- Oil pissed out of both lines when the feeds were taken off to change the actuators so turbos are getting oil.
- There are NO leaks in the cooler piping & definitely no blockage/rags in there.
Basically there is nothing left but the tune..? I was under the impression i should be able to make the boost spike using the previous method regardless as its mechanical?
Could incorrectly set up nismo AFM's cause this somehow? Injectors were also upgraded pre-tune.
Starting to really regret not just slapping a single on! :whistling:
yeah I doubt it's the tune too. if you have tried the unlimited boost trick it should boost hard and fast. it's possible a REALLY bad tune could do this but it would have to be so very, very bad.
Drives just as well as with it connected.
I am starting to wonder if my base timing is out. I did ask the tuner to set it originally, obviously he should of before the tune... but i am running out of things to try here as you can see.
I swapped my engine covers when i swapped the turbos and was unable to set the timing right as it would hunt at idle post injector install. In fact i tried last night and it is still hunting?
Setting the pre-load up on the gates made a HUGE difference to low end, but it was tuned without this.. and possibly with timing out also. Hence suspecting tune.
Yes, i read the whole thread.
I will repeat myself, have you made sure the wastegate flaps on both turbos are fully closed/shut? pretty sure you need the dump pipes off to check this rather than checking how much the flap moves from the exterior arm that the actuator rod attaches to.
I have seen a brand new garret rear housing with a wastegate flap that didnt fully seal against the seat from factory because the hole for the arm that the rod attaches to was drilled off center. It was sent back to garrett.
Im quite puzzled as to what your problem is but thats most legitimate suggestion i can come up with dude.
It would suck to go to the trouble of taking the turbos back off and checking the flaps and seeing how they actually sit to only find that theres nothing wrong with it but i guess, you gotta do it to know for sure.
I do remember having a look before installing and they were sealed flush. I'd imagine it would be quite obvious to the eye if one wasn't sealed correctly?
I'll try to check the timing tonight as i think i can get a steady idle from cold start & go from there. I appreciate the help guys. :)
Edited by endless
if you back the timing off in the tune down low this can help build boost quicker but by the sounds of it its more a mechanical thing.
pull the front timing cover off and check the cam timing then borrow a timing light and set the CAS timing up,
yep, less timing (within reason) builds boost at lower rpm than more timing. more timing will give you boost quicker time wise and make the car quicker overall but it'll be at slightly higher rpms.
I think setting the timing to 15 degrees then going for a blat would be a bad idea seeing as it has been tuned out 5 degrees, also with the turbo response like shit (which has now been solved) think i'll just take it in for tune to be safe.
So...
did you pre-load the new ones correctly? i like to use about 10mm preload.
another thing to check is the cooler pipe under passenger front wheel well (common leak spot)
And finally the bov pressure line often gets swapped with another close one and the BOV leaks under boost. (seen this about 5-6 times)
Well checked the timing ..& it's out 5 degrees. :whistling:
are you sure? check your hand controller "live" timing screen then adjust CAS so it reads the same on the balancer. i often change the base timing as do other tuners.
NEVER ASSUME IT IS SUPPOSED TO BE 20 DEGREES
If you have nistune etc then use consult to hold a particular timing whilst setting.
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
