the way i worked it out was its probably revving to about 7000, maybe a bit less like most ppl do...
the graph doesnt show RPM but it does show rod speed.. so if 180kmh is close to 7000, 90kmh is close to 3500.
its a few rpm off but close enough, boost is definitely well and truly on before 4000. a good achievement.
no way 3500 is 90km :no:
Anyway out of curiosity and boredom I just laid my dyno sheet next to battery's..
Im sure many of you have done this already.. but im posting it.. :D
Not alot in it really, they are running almost identical boost , I have a fair bit more midrange torque and an extra 20kws at 5k, but nose over after 6k where they are both pulling 300kws,
Then he keeps pulling past 7 and smashes me..
Just remembering though I have alot less mods under the bonnet <<read excuse for losing... :Pbatterydynosheet.jpgtune300.jpg
Im not gunna bother comparing anything to Simons freak of nature....
well know how many revs it is if we know where the run ends.. speed and RPM are always relative. you will do double the speed at double the revs in the same gear etc.
nice comparo too :) i cant wait to pop a 20G on my SR
Aaww don't be sad Simon you know your my hero.
Its more the fact I can't be bothered converting all your dynosheet figures to something legible. :laugh:
I think u were making the same as me at 5Ooorpm
On low boost mine is about the same as yours at 5000rpm, high boost close to 30kw more
You guys need to screw more boost in... 2bar or bust :)
Edited by SimonR32
Yeah you can see my 20g making more on the green line but that was 21.5 psi which is 4psi more than the blue line and the gains were insignificant..As Roy said the little comp just can't push any harder ,its giving all she can give..especially on my setup..If I get a better manifold and plazmaman plenum and better cooler it could possibly push for a little more.. But looking at the comparison I would sooner just get a T67 than push this any further.
Not sure why battery didn't push more in..
Got a scanner Artz? I think I could use my broken ass Photoshop skills to overlay onto the same image..
Just re did all my cooler piping in 2.5"(was a mix of 2.25/2.5" before) and now i'm thinking maybe I should move to a bigger Throttle body, not sure if there is much point cause the stock one is still bigger than the 2.5" piping ??
Haha I was putting mine over a picture of yours on the computer, I was gunna trace it but gave up..its almost identical though with yours just dipping a Little between 4-6rpm
That's the same size as my cooler piping I guess there is hope for it yet :D
Got my T67 today and have a few questions.
It came with a 4" Anti surge compressor housing which i did not want i wanted a standard 4" Compressor housing. Will this matter that much?
What is the best way to block the water lines? The shorter of the 2 (Water return??) I was simply going to find a bolt wth the same pattern but shorter and bolt it in nice and tight with a coper washer.
Not sure what to do with the one that goes around the back of the block should i just cut it off shorter and fix a blocked off bit of hose on the other side? Or blank it off at the source, which im guessing is under the plenum?
Any help is appriciated keen to get her back together, tonight i have connected oil feed(One supplied with the turbo is a bit long) and return. Finished replacing exhaust manifold studds.
Also I have one of those NZ manifolds and i am not happy with the way the wastegate pipe comes out it is really really close to the body and air con lines.
Should i modify this pipe or just blank it off and run the gate off the turbin housing?
is this one of the mild steel ones from ebay? i was pretty keen to get one of these for my rb20 anymore negatives?
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
