hypergear highflow or ss1pu .64 for 230ish kw, complete bolt on no hassles.
TD06SL2 20G 8cm for 260kw if you want full external gate no expense on supporting mods spared.
personally I'd put a ss1pu in stock housings on an RB20. Wouldn't even need to think about it.
My predicament is that whilst building a 25/30 id like to have all the neccesary bolt ons ready to go. I dont want something that is too small for the 30 or something to big for the 20. Dont know if that is practacle though. Could a 10cm housing be the way to go when the 30 is fitted. Not after a big power figure just nice reliable engine.
what your wanting is pretty far fetched. its two different ball games unfortunately, and what will be laggy on an RB20 would still be too small for an RB30. thats how different that are.
its really wasted money getting a tune and all that then putting in a bigger motor and needing to do it all again. a turbo that will work on the 30 will just make you cry on the 20.
a nice reliable setup for your 30 though, you can get a hypergear G3 turbo which is more or less a bolt on with the stock manifold and dump pattern. there are videos of a RB30DET R33 with a basic G3 bolt on smashing a 600cc bike on here somewhere. Epic fast it seems, go check it out.
yet if you got that turbo on the RB20 you would need a tiny housing which would still be laggy.... and using the correct housing would be horrible on the 20, and a waste of money to do both as stated prior.
i say wait till the 30 is built.
My TD06-20G is off a twin GTR setup that upgraded to T67s. With a couple of Greddy manifolds one of the TD06-20Gs ended up on my car and the other Fatz's RB30. At the time we were both running 10cm housings and on the 2L RB20 it was too doughy. Changed to an 8cm housing and everything improved. Meanwhile Fatz made something like 245rwkws on 13psi on 98 on his RB30. So would be an animal street car if you ran it to 18psi easily maxing out the 20G compressor without the need to rev the ring out of the engine....
...so I tend to disagree that the same turbo cant serve two different engine provided you are willing to swap A/R of the rear housing
its certainly not that it CANT do it, but rather than you wont want to.
sure enough it will work, but for the effort of a full external gate setup on a heavy breathing RB30 I cant honestly see that it would be justified to make 240kw..
plus, the easiest way to do this setup is hanging a gate off the ex housing and using the stock manifold. if he hangs a gate off an 8cm for the RB20 and then buys a 10cm for the 30 he then needs to get the gate moved over.
just flat out sounds like money is leaking away and overall performance is not on par.
Just saw Fatz made 240rwkws at 10psi :) easky_mad said he is " Not after a big power figure just nice reliable engine" A 20G on whatever boost maxes out the compressor would be a very grunty street car and probably one have to run a very durable 13-16psi. He said he also says he has all the bolts ons ready to go so I dont think it would be a bad option for the situation as he explained it.
A T67 would tilt the balance towards the RB30 with it being a little less suitable for the RB20 but he said he isnt after big power so I take that for a range around what a 20G can do
let me guess you dont like the kink on the straight?
I was never game enough to take it full throttle hey lol...
Full throttle 5th gear right until the kink :) td06 loved it 1.09 in my gtst. Heaps more in it too. No traction tho. Needs a better setup rear end
1.09 pretty good jez..you running stock brakes and all.. Its not the kink i had an issue with, iys pulling the car up after it..lol..I did it flat out to kink the first time, then lift turn brake and nailed it, got 1.17 still..then came off hard on the second and think I kinda lost my nerve after that and resorted to a quil brake dab before the kink, I did have to drive back to Melbourne that night after all...made up heaps of time on the rest of the track and pulled 1.16s all day pretty much..
how were the intima pads jez? I want a set of those also. fark 1:09 is fast.
best I ran was 1:18s, if any of you are on my FB watch the video. I have intentionally edited out the bits that show my car being out horse powered by fairly stock honda civics lol.
the worst part for me was having no real power until 6krpm and the stock 3.7ish diff in the S14. for the most part of the track I was bumbling around in 3rd with no real power.
Ill try post a video tonight if I can.
I wish I had that sort of problem with traction
Makes it exciting. I loved the rush and excitement of RWD on the circuit and not caring if it got smashed up :)
VCT is now working on my gtst, i installed an adaptronic and its working brilliantly. Very inpressed with the Adaptronic ecu's.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
