lol @ and a few skids.
Just get the intake pipe off and check for shaft play. if its anything to worry about it would be that, and it should be excessive to make any noise.
my guess is you have had a pipe shift and its just the sound of turbulence. that OR the turbo to manifold gasket, bolts coming loose.
when my rear studs were sabotaged years back the car sounded like a hektic gum leaf surge slot whistler and then suddenly the gasket let go and it became a diesel. was silent once i changed the turbo gasket.
i have an urgent question for you skyline enthusiats! :)
My car was tuned and running perfectly to suit the old T04E turbo, am i able to drive the car with the new kinugawaTD06 20G turbo without getting it tuned for a few weeks?
It starts and idles fine.
Just keep it on vacuum and cruise conditions and it should be OK.
Don't let it start spooling up though, I've changed cams in a car of mine recently and thought it would be OK to putt around.. Never have I been so wrong. The knock was incredible, am worried ill be pulling the motor my brother just put in the car.
I saw him get tagged with that, nice looking result - 68mm compressor in stock housing is interesting... wonder if they hybrid a TD compressor on there or something funky? No wildly different to a hairbrained conversation GTScott and I had at one point
So it seems no matter what boost we squeeze into the 20G 310rwkws is all she wrote. So the lil TD06-20G has served me well for 10 years in April this year But this week she gets retired.
Whats the verdict on teh billet TD06s getting around. Have any proven they can outflow a 25G yet?
Well I have a 73HTA-TD06L2, TD06H-25G and T67-25G all with 10cm housings. That is probably the order I will try them in as well. If the 73HTA is ncie and responsive and makes good power then will happily flog the other turbos off to try and fund some tyres and track days
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
