Hi everyone,
Am looking at getting a little more noise (being that it's all stealth like and silent at the moment, to the point I can't even hear it running sometimes)
I have been told that the cheapest option with max sound would be a cannon however I dunno if I like that idea :S
1) are they even legal? Because pretty much every cop I've come across hates cannons
2)Will it even sound any good on a N/A
3) Will it look like an experiement from the Western Suburbs
4) I don't want any loss of power
Second option
Replace it with a high flow rear muffler; Not sure about costs of this yet as I haven't rang around/looked on ebay,
Any budget conscious suggestions would be really appreciated, and please no one suggest puncturing it with a screw driver
Is the pipe diameter called 2.25 or 2.5??? Brenton will be installing it for me. Car is a 99 34 GTV
EDIT: Basic idea of what I'm trying to achieve is *Little more noise; enough to make it sound like a Skyline *No loss of power; I can live with the silence if I'm going to loose to much power * Not wanting it to look like an experiment; would like clean and sleek.
Edited by slinky-minky
https://www.sau.com.au/forums/topic/348068-exhaust-options/
Being an NA. I would look towards a 2.5" Catback system with a Sports muffler (but not a cannon). Its all well and good to go a cannon. Noise with a cannon is awesome when your on the power, but not that much fun when your trying to just drive around unnoticed.
https://www.sau.com.au/forums/topic/348068-exhaust-options/#findComment-5598208
You'd probably go a decent 2.25" / 2.5" on a N/A and go with an Oval shape muffler.
Fujitsubo make very good quite mufflers or any Oval shape muffler.
Or get a custom made one and get a sound test done.
Nothing over 90 db and you'll be fine.
Or goto a 2nd hand parts dealer (Import Monster) and get a decent full exhaust.
Don't get anything too loud, cuz you'd be "All Show, No Go".
https://www.sau.com.au/forums/topic/348068-exhaust-options/#findComment-5598210
thanx, my partner is going to make it up but he said he was just going to join the new rear muffler where the stock 1 is then run a pipe and some twin tips he has exhaust pipe the same diamater from his stock fto system and was going to weld the new muffler on after the last flange when it straightens out. will get an oval with no bends inside it so it dosent stick out. only want it a bit louder so this will be good.
btw im on a budget or i would do a better job lol, brenton is going to loosen the flangebolts so i can get a temporary preview of what it will sound like lol, any thoughts on how to make this cheaper/easier/better sounding(considering the last 2 factors)? thanx!
what is the actual diamater of the stock piping?
https://www.sau.com.au/forums/topic/348068-exhaust-options/#findComment-5598339
Brenton: gtv r34 with no rear muffler sounds pretty damn awesome and beefy, bit raspy too but in a good way. chantalle is thinkin of gettin a workshop in melb to do it depending on the prices, she dosent car if the bends are press bent so hopefully it wont come to heaps, think she wants it done for 150 or so, tops. any places that are cheap, to recommend?
https://www.sau.com.au/forums/topic/348068-exhaust-options/#findComment-5598821
My mechanic can do it but he's in Templestowe, a bit far for you I guess...
- http://www.skylinesaustralia.com/forums/topic/348109-exhaust-centre-in-western-suburbsas-far-out-as-epping-area/
Check this tread out Brenton.
https://www.sau.com.au/forums/topic/348068-exhaust-options/#findComment-5599700
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
