You could run less boost at lower gears. This is common on newer cars with turbos. I think the Apexi AVC-R allows this....good luck setting it up.
So you'd run approximately 8psi in 1st, 10psi in 2nd, 16psi in 3rd, 4th, 5th.
Yeah! There we go! Someone that knows what I'm chasing and doesn't make a smart ass remark.
Can my Greddy Profec B II do this?
Props for finally addressing the tuning side of the equation :worship:
So, on the weekend i was making around 240rwkws from my RB20 and on a slippery track that had been wet, but still not quite dry I can flatten 3rd gear. In the dry there is absolutely no problem with traction in 2nd and 3rd. 1st is a bit of a challnege, but if i shift smoothly and sensibly to second and then to 3rd no wheelsping whatsoever.
I gave my suspension to a friend a while back so he could track his R32 and whilst i had his Tein HCs or HR or something in my car I would have the same problem in 3rd gear with it wheelspinning. The springs and valving were too high, or just wrong and ride height was way too low at about 325mm....though it looked cool :)
So as others have said, check ride height is sensible, alignment and quality of shocks good, decent diff and tyres and you will have no problem with full throttle power down in 2nd gear with 230rwkws
Would screwed stock coilys on the back promote wheelspin or improve bog in? Buddy Club BRs are on there way yeww!
getting 'BCs' wont solve the problem, they'll need to be setup properly, then camber alignment will be needed since you'll probably want to lower the height having 'coilovers', then you'll definitely have a camber issue,
if you have stock suspension you shouldnt really have a camber issue, so maybe there is something else wrong, Im using the crappiest cheapest crap tyres but with good alignment and Im holding 290 fairly well with a very responsive turbo.
tuning it out with a a boost controller is retarded... your loosing power/responce.
get some good tyres, ku36's would do the job. and if you still have an issue then i'd be very suprised.
also getting coilovers could make it worse.
Ok I'll just say that my wheelspin comes on at 5700 - 6000 rpm (just before I change gear)
My initial concern was that it was abnormal not to be able to pull all the way to redline but if I'm reaching max power sooner this isn't bad? Its actually better? Yeah?
I will say I'm being quite picky as the car is wicked to drive with or without that top end traction...
Ok. How is this RETARDED?
Optimising power delivery and torque through boost/ecu settings seems to be a fairly sensible option. Would you care to ellaborate? Or were you just shooting your mouth off because others have come out with same shit responses?
Thanks heaps for all the info bro. But...
I HAVE BRAND NEW BRIDGESTONE TURANZAS 235/50/R16 FRONT AND REAR.
Old tyres were some chinese wholesale crap.
Correct I'm on full boost at approx 4200-4300rpm
I guess my main concern was that my car should be able to get to redline before it started spinning but I believe now I'm wrong?
The car drives wicked but not being able traction to redline concerned me. Guess it is my furst turbo haha.
Sounds like I need to get my modulation on :cool:
Bridgestone Turanza = Passenger car tyre, not a performance tyre.
I mean they would have cost what, $100ea or so?
But some proper tyres, or learn to drive.
I drive 280rwkw, with RE001's and i barely have a problem with flat to the floor acceleration unless the road is nasty.
it is abnormal to not to be able to hold that amount of power better than what your describing, less your running a completely stripped lightweight shell with absolutely no weight on the rear wheels.
I dont think your being picky at all, I do think you have a traction issue...
If I push 2nd gear flat I'll get wheelspin at 6800rpm because that where max power is being created, but that is 60rwkw more than what your running, at 250rwkw I didnt have a wheelspin issue like your describing...
so yeah you have a problem somewhere...
but dont just turn your power down, find the issue, get traction, enjoy it even more....
Im using nangkang NS2 tyres and they are a $160 each tyre and are crap and cheap but they serve a purpose to me, Im saving my good tyres for decent driving...
Edited by 75coupe
Oh...is this in your R31?
Edited by plan-b
Im using sumitomo NS2 tyres and they are a $160 each tyre and are crap and cheap but they serve a purpose to me, Im saving my good tyres for decent driving...
Thanks bro. Your time and consideration is much appreciated. We'll see what the shootout/tune holds in store tomorrow!
Screwy coilovers = hell yeh hopeless traction.
Have a look at this vid. I was running 20psi, and about 260-270rwkws on the day. I was running hopeless old Nankang 235/40/18s so nothing extoic.
I run a std 200,000km old RB20 gearbox so dont launch the car hard but you can see second gear has no problems with traction. Dont mind all the problems I am having under brakes...I am in the middle of changing brakes over and did this day to just give the tune and setup a good test. But you can see good traction with that amount of power is not difficult
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
