Does anyone know where I can buy the JJR coil packs i hear they are as cheap as the yellow jacket ones. Its just I don't want to wait for the yellow jacket coil packs, because of christmas it will take ages.
Most people would recommend spit fires for my R34 GTT its true to be honest but, I am not so keen on Spitfires maybe when I start doing some performance upgrades but, at the current moment very basic modifications like exhaust and boost controller so dont want to buy spitfires. Yellow Jackets cost $420 include postage any bright ideas. I cant drive the skyline at the moment until I change the coil packs.
REALLY WANT TO GET THE CAR BACK ON THE ROAD!
https://www.sau.com.au/forums/topic/348596-coilpacks/
Define rubbish?
There are some test results floating around showing they all perform the same as standard coil packs. Voltages and Amps etc.
Most of the time when a coilpack setup is claimed as rubbish, there is something else in the system wrong.
I had them in my 25/30DET, with 1.1mm gapped plugs, making a metric shit ton of torque (Un known as it wouldn't stop wheel spinning on the dyno, or track for that matter... But enough to put 69% injector duty cycle on 880 CC injectors with an 11:1 AFR...) and it never missed a beat.
https://www.sau.com.au/forums/topic/348596-coilpacks/#findComment-5604754
i define rubbish as after useing 3 diffrent sets and the car still miss fired, so they were returned to buy a set of splitfires which fixed the miss fire and never missed a beat again. but that was on a sr20 maybe their rb ones are better
Edited by r32-25t
https://www.sau.com.au/forums/topic/348596-coilpacks/#findComment-5604779
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
