try tipping ice water on the c.a.s when car wont start ( a racq driver told me to do this my falcon )
Common in Fords and Holdens when hot weather and hot motor as the metal in the engine speed sensors 'warp' so to speak in the heat.
Not common for nissans.
Yup I wasn't sure about the external ignitor being on R34s, seems it was indeed ditched for individual ignitors in each coilpack
On that note, try running without the coilpack cover on
  • 2 months later...
Was searching for solutions to this when I found this thread as I have the same issue...
In my case the doesn't really like starting even when cold, but it does start, but is hesitant to do so. I have had it start when warm but it's pretty inconsistent. Inconsistent enough for me to carry a can of start ya bastard in the glovebox.
This is not an ideal solution..
Have replaced Battery (brand new), brand new spark plugs, coil packs (splitfires)
Same as OP.. just sits there turning over forever (or until battery dies), for example BEFORE I bought a new battery, I had someone jump start this car with their car, and a battery pack thing, and I believe the car turned over after about the 150th attempt.
So it starts with start ya bastard?
That tells me there is a fuel supply issue
Yeah, it starts with a quick spray.. 100% of the time, at least the... handful.. of times I've tried it.
I guess that makes sense also given almost everything else is ruled out.. also I suppose it starting when cold, i.e running richer due to.. it being cold and trying to warm up. That said, it's effectively a brand new Bosch 040, that is certainly pumping fuel fairly happily every other time..
Injectors are literally brand new, have done about 100kms. Believe this issue occured (ONCE, while jump starting the car, before new battery too) before they were put in.
For what its worth, car did this.. this morning, at 6am, when it was about 10C outside. I guess it just seems to happen more when warm. If I had to guess, I'd say it just won't kick over about.. 20-25% of the time.
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
