Hey all,
Just need some help regarding my chase for power.
Ive got basic mods at the moment(fmic, and exhaust lol). I want to run a gt3076r but internally gated and on the standard manifold to keep it looking stockish.
Anyway, I need to know what else I will need. Ive done all my reading but I'm stumped on injectors.
Are 550cc top feeds enough? Ive already got a bosch 040 and a nismo fuel regulator. I just need injectors. Should I go 740's? Does brand matter? I see Siemens and this other brand that starts with D going fairly cheap.
Its on an Rb25 motor. Ive found the turbo I want(direct bolt into stock position). Ive set aside about 2.5k for the turbo, injectors and the tune.
https://www.sau.com.au/forums/topic/348743-3076r-for-270rwkw/
  • Replies 50
injectors need to be side feed for rb25. 555s will be enough for 270rwkw but if you can get decent 740s for the same/similar price you might aswell get them, incase you ever go e85.
you'll be sturggling to do it all properly for 2.5k
The turbo I'm getting for $1100.
Braided lines apparently $75 http://cgi.ebay.com....=item4155198a0e
Injectors about $700
Nistune about $700
T3 gasket and 5 bolt gasket about $60
Stud kit for turbo about $100
Its just a tad bit over $2500.
Its hard to find GT3071's. I could always get a rebuild with GT3071 internals as my old turbo was the same... Too many options and seriously when you look at all the options it just confuses me.
The injectors I found are 550cc top feed nismos so I would need a new rail...
Ive removed and replaced my turbo on my old car a couple times. Ive removed and installed the fuel rail my self. Only thing I haven't done was install the fuel pump but there are guides for that. I think I can do the physical/mechanical work my self. I would have someone with me giving me a hand and probably also knows what they're doing so we can do it right.
Denso are the ones I have heard off, pretty cheap too.
Edited by SargeRX8
what about oil drain, 10mm spacer, longer studs, actuator and bracket, dump pipe, intake/cooler piping changes?
then theres oil, filter, coolant etc that you'd change at the same time, it all adds up
I wouldn't need the spacer, well thats what I was told, as the turbo is has a different exhaust housing which will make it fit directly onto the rb25 without fouling against the rocker covers. I have factored those in as worst case. I am going to need an actuator but someone told me I can use the actuator off my skyline and just use the boost controller to take care of the extra boost. The cooler piping is my only concern. I see people running silicone bends and all this stuff, I'd really prefer to get something fabricated. I was quoted about $60 - $100 for the bends made from aluminum.
Ive got all the oils and coolants already(I stock up). Whats the go with the oil drain? The standard one wont bolt onto the new turbo? They average about $8 - $30 over on eBay. I can always pick up some parts 2nd hand.
Exactly... If you have guesstimated it will be $2500 it's going to cost you $5000
I know you won't believe me, but trust me it will :(
what housing is it? none of the garrett ones clear.
cant remember what the standard actuator bracket is like but im pretty sure you cant use it
standard oil drain wont bolt up, bolt spacing is different. you need to buy a pipe/flange to suit and make up the rest of the drain out of whatever you can (stock block fitting with new high temp hose would be best).
Nistune about $700
Your stats say you have an R33 - would think you'll need more than $700 budgeted here, given you'll need to either get an R32 or Z32 ECU, have nistune chip fitted to that, and then the cost of tuning it ..
I'm getting a little scared now :( I'm hoping I can save money on the installation side...
I was told its an AVO housing to suit RB20/25 motors. I should be able to get the necessary parts. Its quite lucky that I posted here, I kind of had my arse uncovered abit...
Shit are you serious? Damnit f**k, I thought it was going to be compatible. Then Ill use a PFC or get a quote for an r32 ecu with the necessary mods to make it work on the r33 + tune. Shit, its gonna add up..
If someone buys my RB25det gearbox it would put $1000 in my pocket :) Or I am willing to trade the box for parts I can use.
450cc S15 injectors, with remap + piggyback, gt3076r internal wastegate .73 AR ($2250 from Adelaide turbo services), auto makes comfortable 250awkw
550cc injectors would be fine for your 270rwkw mark, 290+ would be the happypants zone
Definitely under budgeting and poor part selection.
To start with, do not buy top feed injectors with intention to do an AM rail. This only works when using a Greddy style forward facing plenum. The stock plenum will foul top feed injectors. You will need side feeds OR to highflow your stock items as 10WRB has said.
Contact CEF11E on this forum regarding highflowing your injectors, he knows his work.
As for how to do the job and how to budget for it.. I would do it like this:
A GCG 3076 or 3071 kit for $2950. The turbo on its own is normally about $1700 new, the other $1200 is towards all your fittings such as lines and spacers, new studs etc. The kit also comes with a dump pipe that meets with the stock position front pipe. This kit comes with the CORRECT GARRET .82 turbine housing. The kit you are describing with a turbo for $1100 would have no rear housing, and an AVO housing is roughly $700. The AVO housing will have difficulty holding the right amount of boost and will struggle to make the power this turbo is capable of (as stated 250rwkw instead of the 300 its capable of). The GCG kit comes with THE RIGHT GEAR and is reasonably priced.
Link:
http://gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=538&category_id=56&option=com_virtuemart&Itemid=53
From here you will need the following:
Intake pipe custom made $200 (reasonable expected cost)
Front pipe (if you dont have one already - one piece front and dump will need to be replaced if you have this) $300
Highflow cat (if you dont have already) $400
Intercooler pipes will meet up as the GCG kit comes with the silicon bend
The turbo will now be on the car and running. Now you will need:
Injectors $150-300 to highflow, $400-1200 to purchase sidefeeds (700+cc recommended)
ECU I would go a toshi remap $700ish to be safe - http://www.skylinesaustralia.com/forums/topic/210097-power-fc-and-remap-ecu-road-tune-and-dyno-tune-available-in-sydneysending-to-other-state-and-over-seas-also-abailable-now/
Z32 AFM $300 if you shop around BNEW and then a R31 or VL AFM plug from pick and dont pay less (aka pick and pocket)
So theres your round $5000 or more. By the time you get a few extra niggly bits here and there too, its well and truly over that amount.
Another thing to note, if you opt to purchase the turbo elsewhere (not liking the $2950 price tag from GCG) prepare for the costs to add up very quickly when trying to source all the bits. You can get the lines and silicon bend sorted for around $300 on ebay, however the dump pipe will cost atleast $500 to $1000 depending on who you have make it for you and at what quality. The GCG kit is a reasonable price, do not overlook it.
If you really are tight on money, consider this option:
Hypergear hiflow (can get one made to do 270rwkw) $900-1200
Hiflow injectors $300
Toshi remap $700
Z32 AFM $300
One piece front and dump $179 from justjap (if you dont have one already)
Cat $200 (3" ceramic catco from justjap)
Theres $3000 tops and you will get your 270rwkw. It will not be the SAME 270rwkw, it will have different delivery and the debate about which is better still rages, however it will certainly equate to a decent and FAST car.
I am pretty sure this is the 4th time I have written such a post.. Maybe a guide is in order for the turbo FAQ section (mods let me know if you want this done - im happy to write something up with links and results).
I have a 3076 internally gated smallest rear housing that was supposed to bolt directly up (btw it didn't haha) and all the parts (no labour) for that was just under 3k and I already had an microtech ECU, nismo 740cc injectors, nippon denso fuel pump but i also have a greddy plenum and 90mm TB on a R33 S1 RB25DET.
I only managed to have the car for about 2 days before it blew up again (builder didn't check the clearance on the pistons for the oil squirters lucky I didn't give it all the time I had it :teehee:), but from memory i had ~245rwkw @ 12-13psi (guess at most...it's been awhile) on a safe run in tune and I was aiming for 270rwkw all day everyday.
The turbo I had before was a high flow stock turbo (227rwkw @ 18psi...had the car running for longer then so I can remember >_<) and "felt" virtually the same if not a little later on the 3076.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
