hey guys im looking at installing a boost controller (turbotech) in my R33 GTST S1 soon as i am bored with the speed and the cars ready to go quicker. its my daily drive though so im only looking for around 10 PSI.
heres the following mods already on the car: FMIC, apexi pod, Splitfire coil packs, dump pipe, 3" exhaust (with a cat) GFB BOV, standard turbo, apexi boost gauge, hks turbo timer.
my question is this... will i be able to boost the turbo to 10 PSI or maybe just over whilst still using the standard ECU? or will this extra boost pressure send the sensors crazy?
id like to get away with just using the standard ECU if possible as dont want to spend big money. if not what are my options?? mate reckons ill be able to run it on standard ECU no problems...
any feedback appreciated cheers.
https://www.sau.com.au/forums/topic/348989-1st-time-booster-question/
33's are funny
Mine wouldnt take 10psi, would die at about 5000rpm or so (fuel cut) and was running rich as at 8psi (about 10:1) at this boost with similar mods to you i only made 140rwkw
but in saying that ive seen R33's that handle more boost without to much of an issue
worth a try i guess but I'd def look into getting an aftermarket ECU. There by far one of the best mods you can do. Power deliever is much smoother and nicer.
I have a Power FC and there a great ECU for there age, VIPEC seems to be the way to go now but you could go piggyback in the form of a nistune or greddy emanage or something along those lines if money is an issue
hay bloke 10psi is not a problem and also check ebay for the chips that replace your old ecu chip there like 50 buck no rev limiter or fuel cut it will suit what you want to do. no need for power fc yet. chips come pre tuned, as a matter of fact search this web site there would be heaps of others using these chips and the thred can steer you in the right direction for which one to go with.:thumbsup:
please please please DO NOT buy a pre-tuned chip. chips that are tuned for other cars, or remaps are no good and not a good idea. they can be unsafe and be tuned for unknown specs. my recommendation is when you add more boost, is to tune the car at the same time. get nistune and increase the boost to 12psi and your car will be like brand new. there is a lot of power and response locked away in the stock ecu. so if you fit nistune and boost up your car will be like brand new. a powerfc is ideal, but are a bit more costly than nistune.
paul what are your opinions on a custom tuned chip? ie dyno + road tune to figure out what the maps need to be for your particular car and then burn that data to ROM.
(main downside i can see is that subsequent retunes are expensive).
it depends on how they do it, old style remaps used to be like that, burn once and you have to pay full price to reburn it. i think these days its a lot cheaper and things like nistune dont require you to "burn" the tune if that makes sense. the bummer when selling a remap is they are usually worth $0 to anyone else. if you sell a vipec or a powerfc or a motec etc you usually get your money back, nistune you would as well. just do your checking with a remap, im always a bit wary of them.
you can get the same power/features etc from them, so don't use that as a deciding factor
thanks for the feedback guys. so how much would a nistune ECU cost and where do i get one from? and how much am i looking at to get everything tuned on a dyno? cant i just get a cheaper piggyback like an Apexi safc to sort out any potential problems when running 10 PSI and dyno tune it then?? hm well maybe ill boost it with the standard ECU for now and see if it starts playing up....if it does ill have to fork out for one of these 2 maybe.
Im remapping R33 ecu also power fc and nistune R32,Z32 ecu tuning.
remap is
Chip and install socket Cost $100 real time tune labor $450 total$550
Second hand Power fc cost $1200 tune labor$450 total $1650
Nistune cost around $1000 include ecu and labor.
So remmap is cheapest option but all ecu almost same performance.
Yes,remap is need $100 chip for re tune.(chip can not rewrite)
But how many times tune a year.
If you will tune once a year , only $100 a year.
Nistune is good option.
I saw second hand nistune ecu sold $300.
So I think you can sale $300 but not $500.
my customer car mods is second hand hiflow turbo ($750),
second hand Z32 AFM ($150) and my remap ecu ($650 real time tune).
Total only $1550.
He got 230kw.
This is cheaper than second hand power fc and tune.
before you grab a boost 't ($80) and nistune ($800) or pfc ($1800), which is the next step (160-220rwkw).
do this little mod http://www.skylinesaustralia.com/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/
as the guys have said, you maybe able to run 10psi with the standard tune. but its hit and miss and will run rich and blow crazy black smoke (kinda like a large truck, you may like this...back of the car gets very dirty though...).
give this thread a read as well http://www.skylinesaustralia.com/forums/topic/66556-forced-induction-quick-ref-guide/
put it on 10psi and see what happens, it is highly likely it'll get fuel cut, run too rich and misfire and not make much more power, it might be ok though.
Ultimately you want a z32 computer with a nistune or an r32 computer with nistune and get an ebc like eboost street to control the VCT as the r32 computer can't do that, all of these will be ~$1k including a tune installed give or take a bit. Other option is power fc etc which will not pass an inspection if you get defected, up to you.
Personally I'd do it once and do it properly and get the nistune, no inspector will be the wiser as it'll have a nissan badge on it.
nistune website says i can pick up a type 2 board for $420. and get one of their regional distributors in WA to dyno tune it. but what does all this other crap on the website mean.....
*1 ECR33 RB25DET Skyline can use HCR32DET ECU (no VCT)
or
Z32 VG30DETT ECU (internal modifications required)
*2 BNCR33 Skyline requires BNR32 RB26DETT ECU and O2 sensors???
or check it out http://www.nistune.com/equipment-products-type2.php
The R33 computer cannot have a nistune module put in it, hence you need a Z32 computer (300zx) and then have it wired in and fitted, or you need an R32 rb20det ecu, however the r32 computer cannot control your VCT (variable cam timing) which you really do not want to go without, however you can use an eboost street to control the VCT as you said you needed an EBC anyway.
Email nistune and ask who they recommend in your area to fit and tune a nistune module into an ecu, they will then be able to tell you if they prefer the Z32 ecu or the r32 computer, personally I would just get which ever one is cheaper and get the eboost street either way.
Should be able to get an ECU for $100-200, then get the nistune fitted for $300 and wired in I would say would be around $200 depending on what sensors need to be replaced to get it running as they don't just simply plug into the loom. Usually need a series 1 throttle position sensor, if you have a series 2 R33 then you might need ignitor modules etc as well.
Either way find out who can do the work for you and call them to ask what they recommend, they might have a second hand power fc that is cheaper than going down the nistune route, however it will never pass an inspection and does not look stock, advantage is it is plug and play.
Edited by Rolls
they mean you can use either a r32 rb20 ecu or a z32 vg30 ecu with a few mods (which afaik they now do before selling). the 32 ecu doesnt control vct, so you need an external controller. z32 does control vct so no extras needed.
z32 nistune is the best option for a mild r33 rb25 imo
but first, buy the turbotech mbc and wind it up to 10psi, some cars will run shit, some will be fine. so try it and see, you wont hurt anything at 10psi. just be sure to keep it under 12/13psi at higher revs, you can get away with a little more in the midrange.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
