Yes - I do ignite alot of these fights, but if you can't take a joke, dont respond. ignoring someone is the bigger key to pissing someone off.
Your statement here throws your thread into the paradox of irony.
Looking at this thing in a general, broad view; Skyline drivers flaming Skyline drivers? Rather annoying.
There are two major factors here;
  1. People don't understand that what they write can be taken in the wrong context (given you can't effectively portray tone via text.... yet =.=)
  2. People need to learn to be more tolerant of other people, and accept that maybe they don't mean to flame them.
New chat thread name; "How many pancakes does your hamster wear" or "What have you done to your hamster lately?"(no poly pipe comments, ok?)nyaanyaa.gif
Edited by Daleo
I think it might actually be a rabbit :ermm:
I looked at that, but ears a bit too small?
*Edit* Looks like a rabbit :whistling:
They're still creepy f##kers...
See? C34 & M35 owners CAN get along :cheers:
Just call me "Boutros Boutros Copperart"
Edited by Daleo
hey then call ME Superman, I started the this thread :miner:
Supreman? :blush: Don't they sell womens clothes'?
Seewhatididthere? *Hilarity ensues*
All good Superman, I'm gonna try to do it everytime from now on. You'll have the shits with me in no time...
Bubba: Richard Gere must've known something...pinch.gif He's been bringing people together with smelly rodents for years.
That is fckn wrong mate. Need I remind you that the mind works in images? :dry:
  • Like 2
I've been around almost as long as 66yoHugh but I don't pretend to know everything (or anything if you like). I don't like stretched tyres or noisy bovs but I am quite happy for other people to. Its not the disagreement that's disagreeable its the unnecessary abuse -- I thought that was what Sylvia forums were for!
Peace and Love
...Bob
