Yes - I do ignite alot of these fights, but if you can't take a joke, dont respond. ignoring someone is the bigger key to pissing someone off.
Your statement here throws your thread into the paradox of irony.
Looking at this thing in a general, broad view; Skyline drivers flaming Skyline drivers? Rather annoying.
There are two major factors here;
  1. People don't understand that what they write can be taken in the wrong context (given you can't effectively portray tone via text.... yet =.=)
  2. People need to learn to be more tolerant of other people, and accept that maybe they don't mean to flame them.
New chat thread name; "How many pancakes does your hamster wear" or "What have you done to your hamster lately?"(no poly pipe comments, ok?)nyaanyaa.gif
Edited by Daleo
I think it might actually be a rabbit :ermm:
I looked at that, but ears a bit too small?
*Edit* Looks like a rabbit :whistling:
They're still creepy f##kers...
See? C34 & M35 owners CAN get along :cheers:
Just call me "Boutros Boutros Copperart"
Edited by Daleo
hey then call ME Superman, I started the this thread :miner:
Supreman? :blush: Don't they sell womens clothes'?
Seewhatididthere? *Hilarity ensues*
All good Superman, I'm gonna try to do it everytime from now on. You'll have the shits with me in no time...
Bubba: Richard Gere must've known something...pinch.gif He's been bringing people together with smelly rodents for years.
That is fckn wrong mate. Need I remind you that the mind works in images? :dry:
  • Like 2
I've been around almost as long as 66yoHugh but I don't pretend to know everything (or anything if you like). I don't like stretched tyres or noisy bovs but I am quite happy for other people to. Its not the disagreement that's disagreeable its the unnecessary abuse -- I thought that was what Sylvia forums were for!
Peace and Love
...Bob
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
