why are ppl so unkind? cant we all get along? ect. ect.:3some:
thought i was joining an exclusive family when i bought my stag just didnt think it was going to be like the family i already got!
so much finger pointing dont ya'll realise it takes two to tango?
shouldnt we be ganging up on legnum drivers or something?
But I like Legnum's and Caldina's... can't we pick something else? Maybe something a little more "local"? :)
Would that have more to do with you buying your R32 and unsuccessfully trying to sell the Stag?
the 32 I sold and the stag I kept? :P
I came back online when I had a spare evening looking for wiring diagrams, and found the place in a mess, of course I am going to throw petrol on the fire!
dont even get into it ryan. i even changed my custom member title back to not entice any moar shit. lmfao
either grow up or fck off to m35stagea. info
Edited by dirtyRS4
if youre going to stir up crap dont bother joining the above forum.
we have enough bots spamming it right now!
You're copping it pretty hard at the moment. Is there much you can do about it, or is it a bit of a random thing?
its random crap as we are on google, the bot shows its face and takes our stuff :P
anyway it wasnt hard, came from 3 or 4 IPs that have since been banned. ill have to do it again when it happens next time.
i'de like to see you do any better than m35stagea.info.
get off my thread, i didnt invite you.
Oh cool.
Good choice. :thumbsup:
And now this thread has turned in to a chat thread...
WTF, i haven't really had a chance to jump on SAU much over the break and when I come back on and start scanning threads i find the top threads are all about a bunch of blokes winging at each other.
I don't understand, did we all get a set of overies for Xmas? I come on SAU to talk shit about cars, not get the latest episode of Dr Phil.
The title "all stagea infighting" is B/S, To me it looks like the fighting is only between a handful if people taking everything a little too seriously and the rest of us in the stagea section are sitting back thinking WTF is going on. Come on guys, wash the sand out of your vaginas and get over it.
Edited by QWK32
  • Like 2
Can someone PM me when the school girls have gone back to school and I will come back to the stagea section. :down:
I am off to read some real stuff on Boostcruising. :rofl:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
