MAS Meeting - 2nd March - Girl Promoters/Helping hands
  • Replies 80
Venue has been orangised
Sam has offered up his house (yet again)
Sammi's house is in Toorak
If you are coming, and dont already know the address...
Please send me a PM and i will give you the address.
Thanks,
ash
How much blood can you safely lose in a week cause Im still struggling from Tuesday's mosquito fest!?
:zap:
Just spoke to Cabin - they're keen to give us a big stand and will supply a floor plan with location options once they have it sorted themselves. They are very excited about having the Gibson car there and want to put something in the next magazine about us having it on our stand :D
Leewah: No problem running NO2 on the dyno :D
Sammi: can you arrange a meeting with LFCC for some time next week? Lunchtimes is best for me.
Damn, been so busy at work haven't even had time to check forums....
Not many people know me, but i'm still keen to put my car in or contribute in some way provided i have time... i will try make it.
ps. is the list of cars for MAS finalised?
Sid.
Sounds like it's coming together well! Nice to Cabin pull thier finger out ey! I'll be there on Tuesday night too. And I'm so bringing aerogaurd too.
Sammi - What are you eating man, I reckon it's all that garlic in those pizza's, they cant stand the tatse of you :D
Monkey - If your gonna be there PM me and I'll fill the car with the sh!t
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
