hi guys, im currently owning a skyline gtst r33. I got a problem with my clutch today hope somebody knows whats happening
Its hard to put gear when the engine just starts unless stepping the clutch extremely hardly, it never happend before. It turns to be normal when the car has run for a while.
Its a new heavy duty clutch with new slave cylinder that I replaced few months ago and never been abused.
https://www.sau.com.au/forums/topic/349862-clutch-problem/
