I'm looking for a turbo for a high compression, high flowing 3L motor (Subaru EZ30 horizontal 6) that will make 300awkw on as low boost as possible.
All the new single turbos suitable for that power range on low boost aren't very exciting in terms of compressor efficiency island width because they are all designed for high boost (eg. Garrett GTX, GT and BW EFR)
For example at 0.75 bar, the GT3582R is at least 68% efficient from 22lb/min to 48.5lb/min, a range of 26.5lb/min. The GTX3582R is from 22 to 54, a range of 32lb/min
BUT twin GT2860R 707160-5 is at least 68% efficient from 23lb/min to 62lb/min, a range of 39 lb/min! So it's efficiency starts at the same spot as the GT3582R but ends 14lb/min further!
I want this kind of thing out of a single turbo and I can't see ANY. Is there anything out there?
Edited by bradsm87
https://www.sau.com.au/forums/topic/350072-any-good-low-boost-single-turbo/
  • Replies 40
I wish I damn could but generally a turbo that can flow efficiently for 300kw at say 1.5 bar will struggle to efficiently flow 250rwkw at 0.75 bar, no matter how big the engine. Look at how the compressor maps move up and to the right instead of straight up.
Eg. a GT3076R will make 300rwkw no worries on an SR20 at 1.6 bar but it generally won't make 300rwkw on a 3l motor at 0.8 bar, u need a bigger turbo or more boost.
Also I can't push the turbo to it's very limits because charge air will get too hot because it's going on an unopened engine with 10.7:1 comp cast pistons so I wouldn't want it going past the 70% efficiency mark. It'll need E85 and low cool boost to stay alive!
Edited by bradsm87
I think you will struggle to find anything that will make the power you want at such low boost.
it could be done but would need to be up around the GT40 range. but the lag would out way the benefit of making 300awkw imo.
What about a GTX3582 twin scroll rear and 1.06 it should keep the heat out of it and will close to your power goal on E85..
problem is a GTX35 will be laggy as well. it might make the power but it isn't going to feel crisp at all. it will drive very lazy.
that's the problem with small displacement though really.
i doubt there is any normal turbo that can achieve such an aim on a 2.5L
In the OP he stated the engine is a EZ30 (3L),
but yeah it wont be an ideal set up but will give the numbers he wants and thats about it... :mellow:
Well they are on a 4ltr lol, that's s fair increase[ over a 3.
ah yr, missed that.
either way even with a 3ltr its not going to come easy.
the only way would perhaps be some hybrid turbo, and we all know the lucky dip that goes there.
how sure of this are you? al has a 3076 on his 3 litre and it makes tons of power everywhere and it makes over 300rwkw
why on earth would you go for a Gt35xx when a GT30xx will do what you want, earlier, more power everywhere and should have enough peak
are you saying the 3076 is too small? ref; "wont make 300rwkw at 0.8 bar, need bigger turbo or bigger boost"
if you size the housing correcly then this shouldnt be a problem
ie dont fit a mega small housing and choke, fit a larger size housing
issue is low boost as possible, thing is even with a 3Lwith a 3076 you are still looking at what, 18psi or so?
depends on ones definition of low, but in mine... that's now low, but there is no stantout alternative.
That only solves the problem on the exhaust side. The 76 compressor won't flow 300rwkw at 1 bar. U need to size up turbos to make same power on lower boost, regardless of engine size. eg. The Perrin EZ30 used a GT3582R to start with and made 300-320awkw with a GT3582R at 15 psi.
Looks like the extra cash for twin -5's might be worth it. It would allow shorter exhaust runners being a boxer engine, just a lot more stuffing round with oil/water lines and pipe work.
Edited by bradsm87
yeah agreed... when OP said low boost he meant really low .75Bar
If it was my car i would put the GTX35 on in. then see how much boost it can hanle :rofl:
might even make 400awkw :banana:
LOL at seeing how much boost cast 10.7:1 pistons and pinkey finger sized rods can take.
seriously though, your engine wont last forever making that sort of power and will need a rebuild before too long...
keep that in mind when choosing your turbo.
I know you didn't ask this, but IMHO you shouldn't be worrying about flowing over 50lb/min on .8bar - even on an EZ30, unless you have got pretty fancy with it. Also if you are going to be using a lowish boost level and E85, a few points of compressor efficiency aren't going to break the thing - I'd be worrying more about minimal exhaust manifold pressure.
Look at the compressor map for the Borg Warner S300SX 83-75, I would be leaning towards one of those with the 1.00a/r twin scroll T4 turbine housing if I were doing what you are looking at doing.
People have done cool things with low boost on EZ30s but they are pretty fragile. A mate of mine actually has a forged/turbocharged EG33 in a GC8 which so far makes pretty decent power on low boost though its pretty hard to keep cool haha.
-9 would be the better choice for 300 wouldn't they?
roughly around the 15psi mark is all you should need given a 2.6 needs around 18
this is all subjective as head and flow have a fair factor here too.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
