  • Replies 61
Posted Images
It looks quite neat and of good quality.
Personally I run a non-return valve after each pump but before they join via a "Y" piece. Non-return valves ensure one pump won't fight against the other if pressures are mismatched. The "converter block" on the unit you link too will offer a degree of restriction also due to the sharp change of direction the fuel goes through leaving each pump. I would prefer a "Y" adapter.
Overall, it will do the job I'm sure, just that there is technically a better way of doing it. Just my opinion, of course. :D
I've been told that the car made 372rwkw @ 25-24psi
the boost peaked at 25psi and trailed off to 24psi
last time it was dyno'd at the same place it made 364rwkw @24psi
but on a mainline dyno it made 353rwkw @24psi
<snip>
but this is making no changes other than going from a 3in cat back to a 4in cat back. ( and a tickle to the tune to ensure that mixtures are correct) all that was needed to the tune was a little more fuel in the top end.
What about more timing? Did he try and fail, or not try?
Did the spool rate improve at the high boost end, from say 18 to 24 psi?
^ Agree with the above. Was the tune even touched?
I say that cause for -5s, that's still a fvk load of boost for the power on E85
Everyone else makes that with PULP & less boost :huh:
Also handy you've had it on a couple of dynos etc to rule out one reading totally off and what not.
^^^ on e85? Doubtful.
Powertune do a bolt in kit for twin pumps in tank. Do a search it's been covered before or call them up
Yeah powertune done my twin intake and E85 set up on mine .. top job.
Thanks for the incite will differently look into it further
Cheers
there is an issue of missfire at high rpm, i have to take it back to get my poncams installed when they arrive and a retune will be done with them on there.
i dont know if the timing was touched, i remember him saying that the top end needed a little more fuel because it was running a little lean because of the extra flow but appart from that it was fine.
next time i head around there with the cams ready to go i'll get him to print comparative graphs of the 3in exhaust, 4in exhaust and 4in exhaust and poncams.
and that should show all the differences of all three.
this probably wont be done for a while since i have my wedding in 2 weeks and honeymoon shortly after that.
also its probably not worth pushing the car mega hard on the dyno with all this hot weather we're having.
Yeah i get the before/after... All well and good...
BUT such a change in the exhaust would mean the tune would need to be looked at and adjusted for sure. Without doing so you'll never you realise the full gains of such modification.
the tune was changed,
the tuner had to add a little more fuel higher in the rpm.
also there was a problem with the boost fluctuating which needed to be fixed.
the boost controller was too sensitive and even with the settings changed the wastegates swing arm needed to be modified to not move as much when the actuator opens the gate because the turbine would slow down too quickly when the gate cracked.
  • 2 months later...
Okay,
i've had some further changes made on the GTR
i had type B tomei poncams installed. with no cam gears. so cam timing is zero.
i dynoe'd the car before the cams on 25psi and it ran 360rwkw
put the cams in and had the tuner play around with the tune to get it right on the low boost (20psi) and it made 360rwkw. i thought WIN!! same power, more response and 5psi less boost. then once we were happy with the 20 psi pulling consistently between 360-365rwkw we went to high boost setting of 25psi.
and a whopping big 365rwkw. it varied between 365-370rwkw on 25psi
so in reality 5 extra psi made no difference. the low boost is great, holds boost well, and pulls right to redline.
but 25psi is bad, the boost waves around a little and it seems like it just wont flow? the tuner seems to suspect that its got something to do with the std manifolds not flowwing enough.
its a big job to change over the maifolds, i was thinking if i did that i'd change the dumps to 3in too.
i've also had the system smoke tested and pressure tested to rule out any boost leaks,
just to give a recap of mods here they are:
forged pistons
std rods
R33 GTR crank
260 degree 9.15mm lift cams
-5 turbo's
mines dump pipes (look to be 60 or 65mm)
2.75 in front pipe into 4in cat back
std manifolds
silicone intercooler hoses
ARC 70mm intercooler
K&N air filter in STD airbox
1000cc injectors (siemens)
nismo AFM's
nistune ECU
twin in tank pumps
E85
e boost street boost controller
we've tried opening up the airbox, we jammed a screwdriver to open it up and that made no difference
the ECU and tuning ware responds to changes so it isn't the software, or electronics
he said that it doesnt look like the hoses are sucking closed because you can see the power just cut off when it does that and it doesnt do that. the power just follows the same curve doesnt matter whether its on 20psi or 25psi
please help, if anyone has any idea's as to what it could be or experience of similar results?
manifolds and airbox should be ok...
There's a restriction somewhere between the back of your turbos and ur cat..
"high flow" your cat and get some big dumps and front pipes
Edited by GTR_JOEY
What's a cat?
A fury pet
Na catalytic converter, a small cylindrical emissions killer, look under the car and you ll see it... Smaller then a muffler
Sorry, i was trying to make a joke. i'm not running a cat.
which E85? caltex, united or drum?
united E85
it wasnt sitting in the tank for too long. only a week. so its not like it was in there for months.
united E85
Good to know, I was starting to worry
when he was playing around he added another 2 degrees and it made no difference to the power output.
basically the gains when first tuning at 20 psi were good, but it seemed changes to the tune at 25psi had little to no effect.
you could see on the AFR where if it were running leaner, the power would still be the same. and timing changes had little effect at 25psi either.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
