  • Replies 146
Posted Images
Hi all
Nice to see you all entering
Strictly we prefer people to be a member of a real club for all our events ... keeps the problems away (but if known by people here its fine by me)
For CAMS registered events you must be a member of an affiliated club with them ... well you cant get one of their licences without that. anyway.
Re the Bonnet tie downs .. i think a modern two stage one should be ok.
But I have seen modern cars lose whole bonnet at Winton.
Tying it down is worth while just to make sure.
If you do a lot of track work its worthwhile putting in pins (just make sure they are into real metal).. because i have seen car where they pulled out
If the Scrutineer (who is high level CAMS one) says it needs extra I have to accept his ruling (he outranks me ;-( ).
Currently 36 entered .. i am going to lose money, but you are going to have a lot of track time
Bl00dy Hell those photos of Richo's wrecked car .. it looks much worse than the other photo i saw.
Well it looks like the new wheels i bought don't clear my brakes.... owned! so unless i can arrange other wheels with the right offset that fit my guards AND clear my brakes then i will miss this round.... bollocks :down:
... which was dependent on my car being ready Ash. I had everything organised, but i found out on Friday that Enkei wheels are fkn gay and don't clear my new alcon's so it's either change the brakes or the wheels. I like the brakes so i have to arrange different wheels, in less then a week it's not going to happen. I have 2 sets of te37's at home, none of them will fit this car. I also now have a set of brand new Enkei rpf1 wheels and Advan AO50's which i have no use for. Excellent. So call it a backpaddle if you think the description fits.. I would be there if i could get another set of wheels, and fit the brakes on the car before the cutoff time to enter.
keeping the tyres though right?
i'll sell the tyres too if i can't find suitable 17" wheels to put them on.
For sale thread here if you know anyone interested :Dhttp://www.skylinesaustralia.com/forums/topic/352979-enkei-rpf1-17-x-9-22-brand-new-1400/
Ah cool. I'm going 18's now anyway.
It it still a secret that you are going to the 4cyl brethren of the nissan fraternity?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
