Condition: Used
Reason for Selling: want to get rid of parts
Asking Price: 5
Delivery Methods: PickUp
Contact Info: pm, 0419761510
Extra Information:
Hey guys i have decided to rid my self of all the skyline parts and nissan parts i have accumulated over the last few years. All parts listed below are $5.00 each and it is first in best dressed! cheers guys, Hame rolleyes.gif
R32 Skyline
- R32gtr rear rotor (single)
- R32 gts-t front hard metal brake lines with fittings
- R32gts-t rb20det OEM turbo charger (blown exhaust wheel)
- R32gts-t rb20det dump pipe
- R32gts-t rb20det turbo elbow (off compressor housing)
- R32gts-t rb20det Timing belt cover (embossed rb20 & includes dust cover)
- R32gts-t rb20det OEM throttle body
- R32gts-t rb20det coilpack brackets x 2
- R32gts-t rb20det OEM intake manifold (with everything – valves)
- rb20det afm(unknown condition)
- r32 rb20 standard cam gear
- r32/33 turbo heat shield
- 2 rb20 coilpacks
- rb20det charcol canister
- R32gts-t Air-conditioning grille & line
- R32gts-t rear cradle supports
- R32gts-t gearbox cross-member
- R32gts-t rear tailshaft (centre – diff) x 2
- r32 gtr dash cluster - minus tacho
R33 Skyline
- r33 rb25det coil pack cover x 2
- r33 rb25det brake filler bottle
- R33gts-t air-conditioning grille
- R33gts-t Rear left tail light (painted green)
- R33gts-t door rubber seals (no splits or perishes)
- R33gts-t centre consol
- R33 hazard and dimister button
- R33 climate control unit
- r33 front bar indicator (left side)
- r33 quarter pannel indicator (right side)
- r33 Smart Entrance box
- r33 clock
- r33 indicator stalk x 2
- r33 roof handles $2.00 each x 4
- r33 dash vents <- near windscreen
- Many Interior plastic panels (enquire for price & availability)
- R33gts-t rear seats (both sections, great condition)
- R33gts-t Dash (no cracks)
- R33gts-t rb25det VLSD Diff (wines a little, suit drift)
R33 boot gas struts
- r33 bonnet release cord
- r33 engine bay fuse box and loom
- r33 charcol canister
- r33 horns
- r33 fuse box lid
- r33 radiator supports pair
- r33 wiper motor
- r33 bonnet relase catch, bonnet clip <- bit of metal down the front has horns attached x 2
- R33 gtr rear spoiler (damaged, requires fibreglass)
- R33 rear pods (unknown make, one damaged)
- side door plastics 'skyline' embossed (sill trims)
- steering wheel surround plastics
I know there is no pictures posted here in this add, as u can imagine it would take forever to take them all and upload them so if you require photo's request the part you want and i'll send them to you some how or post them up! Also have more parts available so just ask please and i'll respond when i can! Pick-up can be arranged once contacted. Kind regards, Hame!
https://www.sau.com.au/forums/topic/350403-the-5-skyline-part-sale/
  • Replies 51
Do the boot gas struts for R33 work fine? Mine are a bit weak so wouldn't mind replacing them. Do you have the "tweeter triangle plastic bits" that sit on the inside of the car where the mirrors bolt on?
Do you ever come down to the gold coast?
hey there nah i not coming down the coast sorry, not 100 percent sure about the gas struts have never installed them. ill check about the triangle bits, you dont mean the pillar by any chance? hame
Hey mate no i dont have the shifter surround that has sold! Also to ash s13 i have the release but no horns now, horns sold.
as did:
1 x coil pack cover = $5.00
1 x tail light = $5.00
1 x hazard and dimister button = $5.00
2 x wiper stalks = $10.00
1 x indicator stalk = $5.00
1 x fusebox = $5.00
2 x sill trims = $10.00
1 x steering wheel surround plastics = $5.00
1 x clock = $5.00
2 x kick plannels = $10.00
cheers guys!
Edited by H@ME
have you still got the R33 hazard and dimister button? also the RH plastic that goes up the roof from the front window. and the centre unit that has the lift up compartment between the two seats? are all $5 if available?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
