hi all this is my first skyline build so thought what better place to post it up then on SAU , any advice or recomendations is more than welcomed as im still learning with these cars.
well i gues i better start off on what it is and whats planned
1999 R34 skyline gtt
motor - rb25det
mods - *From what we can see , not from what the hpi magazine issue states*
-apexi gt series turbo - similar to a 3076 with .64 rear housing
-apexi cat back exhaust with titanium lip muffler
-possible injector upgrade
-splitfire coil packs
-autosport aluminium radiator
gearbox-
some sort of twin plate clutch still working fantastic
suspension-
gab shocks
some sort of springs
whitline sway bars
hicas lock bar with everything all neatened up
wheels-
18 inch Volk Gtc in gold
audio-
sony deck
front speakers
body -
wing removed *holeswelded up*
carbon fibre bonnet
interior-
aftermarket gauges in single din slot in dash
recaro millenium bucket seats
recaro seat rails
no rips or tears or scratches
blitz electronic boost controller
current performance - 240kw atw on 19psi - 231kw atw on 16psi on smd dyno in revesby
pretty much since i bought it 3 months ago i have attended a few private drift days and had a hell of a time , but the true intention for this car is to be used for circuit work
up coming mods-
half cage
remote oil filter + oil cooler
some sort of semi's still searching
these will be happening in the next few weeks.
i will be looking into suspension mods as it goes through
https://www.sau.com.au/forums/topic/350437-r34-gtt-hpi34t/
  • 3 years later...
Forgot to update this thread lol
Put on a front lip carbon boot z tune skirts and rear pods
18x9.5 and 18x10.5 varrstoens
Had the whole car resprayed after a incident where the passenger rear quarter and front guard met a pole and fence lol
One of the best handling cars I ever owned still regret selling it after seeing it covered in stickers and no lip :(
https://www.sau.com.au/forums/topic/350437-r34-gtt-hpi34t/#findComment-7306253
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
