Hi all,
I did the AAC and Air Reg clean recently and now my car idles higher then before i cleaned them!
It's currently idling at 1100 and sometimes goes up a couple of hundred.
Not sure what the problem could be.
Tried turning the AAC screw but wouldn't bring the revs down and if i turned it down to much the car stalls when engine is cold but when warm it stays alive but idles 1100+
Anyone know if the Air Reg is meant to have a tiny gap/hole when normal? I recall when i assembled it together after cleaning it i looked through the hole/pipe and i noticed it's not fully blocked off and there was a little gap/hole.
If that should be fully closed then that might be why i got high idle?!
Any other suggestions would be great!
Thanks.
https://www.sau.com.au/forums/topic/350588-air-regulator-hole-open-normally/
You need to disconnect one of the plugs on the AAC valve I'm pretty sure to adjust it
Or maybe one of the TPS plugs?
Sorry don't remember which one. But once you do this your revs will drop so if you've wound it in it might stall.
i had a funny feeling it was the aac plug because if its still plugged in the computer can open or close the AAC valve? But hey it probably is the TPS. It should work if you can get it into base idle mode anyway.... dunno why it wasnt changing the idle
Screw in for revs down and screw out for revs up I think?
Been far to long since ive had to do this lol
Perhaps try resetting the stock ECU if its still the standard one
the idle adjust screw has a small rubber o-ring around the inside. maybe when you put it back together you left the o-ring out? it shouldnt even be removable really, from memory it has a strip in the centre that is threaded thru the middle of the idle screw. but mine had come off when i pulled it apart.
Unplug the AAC when adjusting the AAC idle screw. The air regulator should be fully open when cold and will close as the engine warms up. It should be fully closed when the surrounding temp reaches approx 60degs.
according to the r33 workshop manual you only unplug the AAC valve on a GTR. on rb20 and rb25 powered cars you unplug the TPS.
If it is an R32 with RB20DET the AAC connector should be disconnected which is the same for the R32 RB26DETT. If it is an R33 or R34 RB25 it is the TPS. I double checked with the R32, R33 and R34 workshop manuals.
Cheers
  • 3 weeks later...
Cheers
This sounds about right
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
