maybe sinse the fact that Clutch is in Melbourne, as well as Miss_R34, they should meet up.
Clutch seems to like her, and from the post's, Miss_R34 seem to be the only one who likes clutch. cupid?
its cos she hasnt been brainwashed by teh evils of sau yet
everyone eventually hates clutch
lolz
https://www.sau.com.au/forums/topic/350613-new-girl/page/9/#findComment-5653757
I would lol so hard if miss r34 rocks up to a meet one day and it isnt miss r34.. its mr sherrin with a f**k of big mullet and missing teeth...
no offence to you missy.. just sayin
Lol Mohsen - you never know hey ;p I'll make sure to come and say hello to you personally - then you tell me what you think ;p
https://www.sau.com.au/forums/topic/350613-new-girl/page/9/#findComment-5654153
Lol cupid Aaron ;p
https://www.sau.com.au/forums/topic/350613-new-girl/page/9/#findComment-5654174
Lol cupid Aaron ;p
either that or collect and select.
Lol syfon got told!!!!
Yeh come say hello....
If you really are a lady boy version of bogan sherin I'm locking myself in the car lol
so now you can choose from Syphon Clutch or Mohsen.
And if she turns out to be a he, I want to take a picture of the reaction hahahahha
https://www.sau.com.au/forums/topic/350613-new-girl/page/9/#findComment-5654976
Gimp - you failed miserably with your signature.
better luck next time though. lol
Edited by AaronNM35
https://www.sau.com.au/forums/topic/350613-new-girl/page/9/#findComment-5655955
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
