Hi there guys and girls, i am currently parting out a Black 2 door R33 S2 Skyline. i have sold the engine, gear box, suspension, and brakes but most of the other gear i still have around the place. i also have parts from a S1 RB25DET which i was in the process of rebuilding, but moneys an issue, so parting it out
  • RB25DET Head (stock condition and in very good condition, comes with rocker covers and valves etc, no plenum or coil packs or exhaust manifold) $250
  • 2x RB25DET Lower portions of the intake plenum (part that bolts onto the head) $75 each
  • RB25DET alternator $60
  • RB25DET Power Steering pump with bracket $100
  • RB25DET Throttle body $50
  • Stock BOV $30
  • S1 RB25DET coil packs (working order) $100
  • 2x Apexi BOV $50 each
  • Manual Brake pedal $20
  • Manual Clutch pedal $20
  • Slave cylinder, lines and piston (that pushes on the fork) $30
  • R33 overflow bottle $20
  • Engine fuse box cover $10
  • Complete Front hubs with upper control arms $70 each (got both Rh and Lh)
  • Drivers side Rear tail light (white in colour) $60
  • Windscreen wiper motor $15
  • Passenger airbag (not deployed) with wiring $100
  • Air bag module $60
  • Stock R33 rear strut brace (silver with red SKYLINE writing) $100
  • 2x Rear Hicas units $30 each
  • RB25 engine cross member $100
  • S2 steering wheel with airbag (un deployed) gd condition $140
  • A pillar plastics (2 sets) no holes $20 each
  • HKS (J tank) inter cooler (smaller intercooler, bit of fin damage) $100 with piping
  • Apexi Radiator (with apexi radiator cap, slight fin damage) $200 ono
  • S2 glove box and surround $40
  • Rubber manual gearbox boot with steel ring $30
  • Stock front and rear sway bars $40 each
  • Passenger side mirror (white in colour) $40
  • S2 black front grill $80
  • Rear garnish - part between tail lights $50
  • RB25 12psi turbo actuator $50
  • Pod filter adapter (to put a large pod filter on) $30
  • Black drivers door handle $20
  • Space saver $50
  • Black boot lid with s2 wing $150
  • Stock R32 GTST springs (good to get off defect) $100 for all four
  • Earthing Kit (Hot Earth) $50
  • A/C Fan $100
  • S2 front guards (2x White and 1x Black) $100 each
  • S2 Front and Rear seats (perfect, apart from small hole in drivers side) $200 the lot
  • S2 Ash Tray $20
  • Drivers power window switch (no surround) $40
  • Passenger door window switch $40
  • Electric side window switch $30
  • Petrol flapper door (white) $10
  • Passenger door, with glass (black) $120
  • Rh adjustable Castor rod (unknown brand) $40
  • Rear Quarter Panels with side glass $400 a panel
  • Rear windscreen $75
  • Door seals (good condition) $20 each
  • Bonnet latch cable $20
  • Boot latch cable $20
  • Stock fuel pump $30
  • Steering column with barrel and key $75
  • Complete s2 floor carpet $50 (no holes)
  • s13 Silvia 4 stud rear hubs, rotors and brakes $100
  • All interior plastics as well
i have lots and lots of parts, so shoot me a pm and just ask or if you want pictures of anything again happy to get some for you. Happy to post at Buyers Expense Cheers Ty :thanks:
Edited by sus 32
https://www.sau.com.au/forums/topic/350873-r33-series-1-2-parts-to-clear/
Mate,
Manual Brake pedal $20<LI>Manual Clutch pedal $20<LI>Slave cylinder, lines and piston (that pushes on the fork) $30
they mine. if you got them. belive they in good condition. how much postage 4 sydney 2113. please pm
HKS front mount - Sold
1X washer bottle - Sold (one to go)
S2 Ashtray - Sold
A/C Compressor - Sold
S2 power antenna - Sold
most other parts still up for grabs!
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
