hey guys
just replaced my o2 sensors but from what ive read, i think something maybe wrong. o2-1 reads a .8 to .9v at idle. o2-2 sits on .06v. ive given it a bit of a rev and they both move but i would think they should be the same voltage.?? i used the rb25 (NTK OZA395-E2) *2 with plug modification
https://www.sau.com.au/forums/topic/350894-o2-voltages-in-gtr/
hey guys
GTR's trim the front 3 and the rear 3 cylinders independantly so they will neverread the same while in closed loop.
I'm not sure if I would trust either's voltage output, when fully warming up at idle you should see 0.4-0.6v.. but if they are indeed working then the first 3 cylinders are running rich (assuming o2-1 is the front sensor), while the last 3 are running lean
They will only really trim once its hot and on cruise. Try bringing the revs up to 2500rpm hot and see what you get - if one goes lean and the other rich - then you have most likely wired them around the wrong way (the best check is to watch the fuel trims as you will see one go to full positive trim(25%) and the other to full negative trim(25%)). ie front 02 signal in the rear dump and rear 02 sensor in the front dump.
just give it a rev to 2500. 02-1 sits on .9 to 1 v. o2-1 sits on .08 to .09.
checked the wiring, long plug goes to back, square plug goes to front (can someone confirm this please)
wires are in correct positions(same color wires go to heaters and same to signal wire across to plugs)
where do i see the fuel trims?? had a look in the screen for o2's and couldnt see them there
just went through my pfc screens and it turns out the o2 f/b control was turned off. there is another one, 02 sensor reg. does this need to be turned on too? must be a gtr thing cause i cant find it in any manuals
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
