hey guys, got this a little while ago,
1998 260RS stagea
so far I've upgrade the exhaust a bit (front pipe and cat before it hit dyno, just replaced rear muffler and trying to get a 3.5" resonator), taken boost restrictor out and installed a Bosch 044 and a haltech. Currently putting down about 210awkw's with a restrictive exhaust.
Next plans are twin plate clutch and a pair of Garrett turbos. (2860's -5)
the wheels on it in those pics are my mates (18x9.5+18) and I just run the autech stockies
Let me know what ya think guys!
https://www.sau.com.au/forums/topic/351191-brendans-260rs/
Yeah the front needs a little more low (it's running fully adjustable Zeal coilvers)
My mate bought those wheels for his JZA70 supra not long ago so I don't think he'll part with them (even tho they look sexual on my car lol)
see how I go I guess haha.
https://www.sau.com.au/forums/topic/351191-brendans-260rs/#findComment-5635971
Looks good and very similar to mine. Very similar number plate. I'm curious to know how much power it will have once the exhaust is done. Mines currently pushing 190kws at all 4 but is being limited by injecters. getting a fuel pump and fpr fitted soon!!!!!!!!1
https://www.sau.com.au/forums/topic/351191-brendans-260rs/#findComment-5635975
You must be kidding! My RS4 with an RB25DET made over 200awkw with stock injectors. Anyway don't bother with the fpr - get some better injectors and an aftermarket ecu for a start.
https://www.sau.com.au/forums/topic/351191-brendans-260rs/#findComment-5635985
Yeah i got 244.5 at the rears on stock turbos and just a walbro in my 260RS, pretty much every other bolt on know to man though. Power FC and Z32s are the go.
My tuner tells me stock FPR will be fine when i add 2860s and 700cc injectors,
Nice plates dude, These things look amazing dumped but the overhang at the front is a real killer i couldn't imagine going too much lower.
https://www.sau.com.au/forums/topic/351191-brendans-260rs/#findComment-5636132
Yeah my stag has 227 I think at the rears with the exhaust dropped... Think it lost about 4kw with the cat attached. K&N panel filter, haltech, 044 and 1 bar are my only mods.
And thanks, saw the plates were aailable and purchased them before I bought the car haha. They were going on a vz if I hadn't bought a 260 when they arrived (had to have a car to put them on in order to order them). Luckily they weren't tainted by commodore faggotry lol.
https://www.sau.com.au/forums/topic/351191-brendans-260rs/#findComment-5636244
just read that they arent your wheels... spewin...
although i havent seen it on an older model stag but i have them on my m35... ive got a set of v35 skyline wheels on mine currently, actually look pretty good, they have a convex styling to them so they kinda POP a bit!
but yea any wheels can look good, spacers provided!
so jelly of your 260rs, was going to import one actually but i caved for the newer stag, about the same price anyway... had a gtr before and maintenence on rb26 ruins my life lol
https://www.sau.com.au/forums/topic/351191-brendans-260rs/#findComment-5636300
Stock FPR is fine for heaps of power on an RB... only those who are avoiding an injector upgrade tend to play with them.
Take it to another workshop for a second opinion and get them to check the fuel system over, a pump on the way out(for example) could be causing issues for you(or a pump at its limits...), injectors are fine for a fair bit more. Workshop or car seems NQR :thumbsup:
https://www.sau.com.au/forums/topic/351191-brendans-260rs/#findComment-5636313
yeah it's a nice car and I'm in love with it. Always wanted a GTR but I've had a few 2 drs already so I thought I'd get something practical and fast :)
https://www.sau.com.au/forums/topic/351191-brendans-260rs/#findComment-5636842
The same reason I got my 260RS. A family car... with some serious horsepower.
https://www.sau.com.au/forums/topic/351191-brendans-260rs/#findComment-5636990
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
