hey fellas
got heaps of bits and pieces from a half cut I just stripped
Intercooler (couple of dents here and there but you cant see it once the bar is on) $100
ABS pump and hard lines $150
After market BOVs cant see a brand on em $100
A/C condensor $150
Alternator $80
All Left hand control arms $300
Left drive shaft (needs a new boot) $80
Left hand hub $100
Cross member $150
Sway bar $50
Brake booster with master $200
Clutch master cylinder $100
Clutch slave cylinder $100
Nismo Coppermix clutch with nismo flywheel (hardly been used almost brand new) $1500
Bare half cut no damage $400
prices are just there because i have to put em up
im open to all offers on everything so shoot me a PM and we'll go from there
there is probably a million other parts ive forgotten but if you need anything just PM me and ill let you know
https://www.sau.com.au/forums/topic/351399-fs-r32-gtr-half-cut-left-overs/
ive got a couple harnesses at the shop ill have to check.
clutch, hubs, cross member, sway bar, radiator all gone
cooler, aftermarket BOVs, clutch master and slave sold pending payment
Gearbox has gtg any reasonable offer will be accepted.
Also have stock BOVs and re-circualtion pipe
HKS intercooler piping
front crossmember?
do you have the BOV pipe that runs through the drivers side frame rail?
Sorry Marko my one is rat shit LOL I reckon I'm just gonna get a brand new one and be done with it same with C pillar trims.
I have a pair of damaged indicators but no immaculate ones.
do you have the a/c lines from the condenser ?
Nah sorry dude only got a condenser.
do you have the air con/ heater controls and can u send them to adelaide?
Ill have a look and get back to you tomorrow
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
