]Well got around to installing my catch can on the weekend and i went with this set up. Can any one tell me if this is correct way of doing it and if its working properly ? Any thoughts would be great. Car seams to be running fine but has a miis under boost but i think that due to plugs or coil packs cause just went on the dyno and had boost turned up . post-78172-0-11146500-1295788660_thumb.jpg
Yeah that's got the PCV catered for, but you can also run the valve cover breathers to it too.
It's prob better for the engine to vent it to air instead of back into the intake, but it's not very legal that way...
Pretty sure that won't work. You still have it set up so that oil and oil vapour can be sucked into the intake side of the turbo, particularly under boost (high load) conditions. And that is exactly when you don't want it to happen.
The PCV valve only opens under high vacuum (low load) and detonation from the oil vapour isn't a problem.
Yeah but then you have to vent it to atmo which is not legal.
How is that different to how hes done it, still has the PCV and plumbed into the intake?
edit: my bad I thought he had done it like you had, you are right that is the better way to do it. When on boost it sucks the gasses via the catch can, when on vac it sucks straight out the cam covers avoiding oil in the turbo.
His is the opposite, when on vac it sucks via the catch can, when on boost it sucks the oil straight out of the cam covers into the turbo.
Edited by Rolls
thought i might of f#!!ked it. So what u have done is plumbed the catch can between the cam cover and the pvc taking out that pipe all togeather? did u notice a difference? will hook it up ur way just means bigger pipe and larger barb ends on the catch can witch will be a bitch to find. Thanks for the pics mate.
No you don't!
Here's mine, stil complying with the requirement to have a fully sealed system not venting to atmosphere:
and you always run those hoses that close to the fan????
Thats better, you'll pass an epa/defect inspection with it set up like that as well.
I would have used black hose under the intake piping personally, but its functional at least.
Edited by Rolls
nup still to close for my liking, I especially like the black electrical tape holding it in its 'safe' position... come on really you couldnt find a safer place to have them or is that all the hose you could afford...
yeah i know it stands out a bit just a quick install got to fly out for work tomorrow so got some hose and fittings on order for when i get home plus don't really like the brass fitings i used. It won't stand out so much then. thanks for the advice guys.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
