g'day
i decided to build a 25/30 for my vl after seeing the results people on here have achieved quite cheaply on here
parts i have sofar:
rb25det s2 head - has bin welded and is getting machined and pressure tested atm.
ebay rb25 highmount turbo manifold
greddy copy plenum
6x bosch mec717 coil packs
sard 660cc injectors
microtech lt12s with x6 igniter and microtech loom for rb25
pro boost t66 turbo 1.00 rear 1.07 front (from memory) - may go for a 35/40
tial 42mm waste gate
ebay intercooler with 2"-3"piping
3" vband dump pipe from turbo to cat
3" mandral bent exhaust
malpasi fuel reg
r33 gts-t gearbox
brass button clutch
surge tank
new rear main seal
to buy:
head gasket
head studs
oil pump
new water pump
sump gasket
044
timing belt
oil restrictors
t3-t4 flange adaptor (or weld on t4 flange)
there are other little things i have prob forgotten but ohwell.
my plan is to use the rb30e bottom end that is in the car now, put in 1mm oil feeds and a new oil pump (which one should i use?) and bolt the head on with arp studs and a genuine nissan rb30et head gasket and hope for the best. any ideas how far i will get? im putting an rb30et in while im building the 25/30 just for fun
later on down the track i may go all out with a full forget 25/30 setup using parts from this setup
thoughts and opinions?
cheers
Edited by the_jack
https://www.sau.com.au/forums/topic/351713-my-2530-build/
  • Replies 45
oil feed size depends on oil pump used, use of the car and whether or not your using them to feed vct aswell. if your buying an oil pump i'd get a 25 pump, otherwise use whatever you've already got.
sump doesnt have a gasket, use some high temp gasket silicone.
timing belt will also determine what you have to do with tensioners. if using a 150T belt (such as the gates 30det belt) then use 2 tensioners in the standard locations (next to each other down the bottom), if using a 152T belt then you need to relocate one tensioner as per the 30det guide.
also i'd steer clear of the malpassi reg, standard ones are much better....
https://www.sau.com.au/forums/topic/351713-my-2530-build/#findComment-5642037
yeah im planing on runnung vct and was going to use a 25det pump. i was also planing on running the gates 30det belt
https://www.sau.com.au/forums/topic/351713-my-2530-build/#findComment-5644968
well if your doing the internal vct feed from the cam buckets then you need enough oil to supply that aswell. standard 25 has 2 main 1.5mm feeds and a 1.5mm feed for the vct, so 3 x 1.5mm feeds all up. i personally used 2x1.6mm feeds with a 25 pump and vct, which works out to a little less flow than standard 25 setup, havent had any issues yet.
gates 30det belt is 150T so use 2 tensioners in the standard locations down the bottom, make sure the belt doesnt get too close to itself
https://www.sau.com.au/forums/topic/351713-my-2530-build/#findComment-5645183
  • 3 months later...
turns out the head i purchaced had leaking valves so iv had all new seals put in it and should be getting it back next week. also iv picked up an rb30e with only 140xxx km on it so i should be putting it all together in the next couple of weeks
https://www.sau.com.au/forums/topic/351713-my-2530-build/#findComment-5811871
  • 2 months later...
update:
ended up scrapping the ebay exhaust manifold and picked up a 6boost manifold nice and cheap. have got just about everything to put it all together now except for a TPS, timing belt, spark leads and a few other bits and pieces.
this week im going to drill out and fit my oil restrictors then bolt the head on (finaly)
question time:
i have bin told i can just press in the new oil restrictors ontop of the factory ones?
i already have a stainless T4 flange i brought for my other manifold, is it possible to chop off the T3 flange off the 6boost mani and weld on the T4 flange?
where can i buy my timing belt from? iv looked everywhere but the part number listed in the how to thread is different to the ones listed on the gates website.
with the VVT oil galery on the rb25det head, what size should i drill it out to? Im useing 1.6mm oil restrictors in the block.
im useing an rb25det oil pump. will it fit straight on the rb30e crank or do i need a crank collar such as a spool imports once?
cheers
Edited by the_jack
https://www.sau.com.au/forums/topic/351713-my-2530-build/#findComment-5919855
just tap the restrictors into the block and push the old ones down, no need to drill them out or anything.
you can use either the gates 30det 150t belt or the 152t dayco. if you use the 150t and your head and block havent been machined down majorly you can use the 2 factory tensioner locations at the bottom of the block. if you use the 152t belt you must relocate the tensioner as per the guide.
i drilled the brass plug out to 1.5mm as thats what the standard 25 vct feed is.
25 pump will go straight onto the 30 crank, however you'll only have a narrow drive so dont go bashing limiter too much.
Edited by JonnoHR31
https://www.sau.com.au/forums/topic/351713-my-2530-build/#findComment-5920214
you dont NEED to, but it'll be stronger with one. to fit a crank collar you need to remove the crank and get it machined to suit the collar, then fitted and grub screwed. or you can get the crank welded then machined with a wide drive.
if your motors already assembled and your not planning on bashing limiter constantly at crazy revs i wouldnt bother.
https://www.sau.com.au/forums/topic/351713-my-2530-build/#findComment-5927824
yeah since its not a built bottom end im not going to be limiter bashing too much. oil pump is already on the motor anyway :)
dropped my 6boost manifold off to get the t4 flange welded on thisarvo. going to finish cleaning the block and giving it a coat of paint this week then going to assemble everything next weekend and about time!!!
https://www.sau.com.au/forums/topic/351713-my-2530-build/#findComment-5930580
got my manifold back from being modified on friday so i bolted up the hotside to see how much room iv got. just need to figure out where im going to mount the waste gate now as it had to get cut off to make room for the t4 flange
https://www.sau.com.au/forums/topic/351713-my-2530-build/#findComment-5941876
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
